retrotech
Nov 7 2005, 09:37 PM
Please send pictures of different locations of Kill Switch.
Thanks
TINCAN914
Nov 7 2005, 09:44 PM
If you could also inclue your address that would be nice....
I wasthinking about installing one as well, when the car is ready to run. Suggestions would be appreciated.
Rider914
Nov 7 2005, 09:50 PM
somewhere you can reach with your left hand, while your right hits the key.
thieves lean to the right while they crack the collar with a BF screwdriver, ducking so that no one will see them.
My favorite for a SUV is a switch that sends the fuel gauge to E. A tank of gas is worth more than the car.
Grimstead
Nov 7 2005, 09:51 PM
If I was to use one (not saying that I am), I think a good place to be would be attached to the fuel pump in the front trunk (not that I have one there). THis would give you the double protection of a locked hood and a kill switch on the fuel pump with no way to bypass (not that I have put one there).
PS, As of Today, my best theft protection is the four jackstands holding my car up.
TINCAN914
Nov 7 2005, 10:54 PM
The jackstands are great security...
Years ago I leaned of a cheap security system. I length of chain, approximatley 24" long and a pad lock. Wrap the cahin around the clutch and brake pedel. Can't shift without locking the brakes, I did this after my car was stolen 10 years ago, until I got a security system installed. They came back a week after steeling it the first time. It works.. They backed out under the car port, and found they couldn't shift. THere it was left..
URY914
Nov 8 2005, 07:43 AM
QUOTE (retrotech @ Nov 7 2005, 07:37 PM) |
Thanks |
Do you mean a racing kill switch?
I think SCCA covers location in the rule book. I think it says something about in the event of a roll over the worker must be able to reach it. I mounted mine close enough that I can reach it while belted in my seat.
Paul
retrotech
Nov 8 2005, 10:58 AM
yes, I was referring to racing look/application.
d914
Nov 8 2005, 12:42 PM
mine was in the side engine grill over stock battery location, I have also seen them in the front cowl. I also have a master kill switch on the dash.
