effutuo101
Nov 11 2005, 10:40 AM
both of my rear latches on my top started to go. Then I noticed yesterday that the hook on one has started to bend causing the top to rattle. Anybody in the Seattle area know where I can pick up those as well as all of the ebrake stuff? Thanks
Chris
SLITS
Nov 11 2005, 10:43 AM
To the Classifieds and beyound
I prolly have the rear latches...handbrake maybe
Bleyseng
Nov 11 2005, 10:55 AM
I do have a set on early latches if you need em quick.
Rich at HPH is the easist place to get parts like this I have found. He even has brand new handbrake levers last time I talked to him.
18779144YOU is the number
Rough_Rider
Nov 11 2005, 10:56 AM
Have same issue. Prolly because i used to much force to tighten em down.
If your carefull you can re-bend the hook part after heating them up. Hold em in a vice, apply heat.
Other tricks, remove the mounting plate, the one attached to targa bar. Elongate the holes so the whole assembly can be slid down a few milimeters.
Or place a small rubber gromit over the pin that on the roof.
effutuo101
Nov 11 2005, 10:58 AM
Thanks! I will give him a call and if that doesn't pan, i will try the heat trick.
