Aaron Cox
Nov 12 2005, 09:59 PM
ok. so i currently have a 5 bar (80 PSI) dual sender on my motor.
i have a 904 gauge with a 150 PSI range (10 bar)
will
QUOTE |
Oil Pressure Sender, 150 PSI dual sender VDO-360023 |
from pelican work with 150 PSI 911 gauge insert?
goose2
Nov 12 2005, 10:11 PM
it should...the Pelican guys should be able to tell you for certain
Aaron Cox
Nov 12 2005, 10:14 PM
it will work with the pressure side of this gauge? (or pressure insert for that matter)
cool. got an order to place at Pelican soon.... ill call glenn sager (a914luvr)
jim_hoyland
Nov 12 2005, 10:34 PM
Isn't that what I just did ?
Installed the 10m bar sender on the 904; pressure gauge works.
Aaron Cox
Nov 12 2005, 10:40 PM
QUOTE (jim_hoyland @ Nov 12 2005, 09:34 PM) |
Installed the 10m bar sender on the 904; pressure gauge works. |
just double checking jimbo.
thanks bud
AA
ein 6er
Nov 12 2005, 10:49 PM
i have a 904 gauge also, and i need the correct duel sender. how do you know what PSI your gauge is? what is the part # of your gauge?
doug
Aaron Cox
Nov 13 2005, 10:07 AM
QUOTE (ein 6er @ Nov 12 2005, 09:49 PM) |
doug |
if it is the 1 - 2 - 3 - 4 - 5 that is in BAR or (80 psi)
the one in my gauge
is 140 psi, or 10 bar....
ein 6er
Nov 13 2005, 02:44 PM
thanks aaron!!
i get confused looking at this list of matching gauges and senders. it doesn't show a dual sender.
