take billy squier's advice... "stroke it"
a 2.0L crank and 96mm pistons will make a nice 2056cc engine...
btw, you need a 3mm bore out on your cylinders, not 2mm.. the 1.8 is 93mm not 94mm
also a huge improvement will be to go dual carbs... a singe weber progressive(what most single-carb setups use) isn't enough... 2 weber 40's are a great addition and are big enough for you to increase the engine again later.
