Hammy
Nov 14 2005, 07:09 PM
My teener has plastic fuel lines going down the outside of the driver's long, hidden under the rocker panel. Was it factory like this? I thought they all went down the center tunnel. Doesn't matter, I'm replacing with steel lines, just wanted to know...
SpecialK
Nov 14 2005, 07:14 PM
Down the tunnel like you thought.
Mueller
Nov 14 2005, 07:16 PM
are you sure those are for fuel...some cars had the evap lines for the charcol canister installed on the sides.....
fuel lines on the sides are a bad idea.....
Nov 14 2005, 07:20 PM
| QUOTE (Mueller @ Nov 14 2005, 06:16 PM) |
| are you sure those are for fuel...some cars had the evap lines for the charcol canister installed on the sides..... |
if they're black, they're "air" lines for the evap-system ...
Andy
Dave_Darling
Nov 14 2005, 07:22 PM
Yup, those are almost certainly for the carcoal cannister (evap emissions control) system. All US-spec cars (except a few that slipped through the cracks) from 70-mid 74 had 'em; the late-74+ cars had the cannister in the engine bay so there was only one tiny little line in the center tunnel and no driver's side air lines.
--DD
Hammy
Nov 14 2005, 07:58 PM
You guys are right. Now that I have the tank fully out I can see they were air lines. Fuel lines go down the tunnel like normal
thanks guys
