DougC
Nov 15 2005, 03:19 PM
Well it looks like the set of stock seat belts that have been in my garage are junk and I won't be able to use them. So, I need some replacements. I thought before I start looking for a stock set I'd enquire about after market 3 point units. Anyone here have them in their 914s?
Doug C
bondo
Nov 15 2005, 03:20 PM
I have 924 belts, works like a charm. Cheap from pick-n-pull.
DougC
Nov 15 2005, 03:27 PM
OK, I meant to ask what other belts would work.
Doug C
MattR
Dont seatbelts go bad after a while? Why not invest in new belts?
Tobra
Nov 15 2005, 03:31 PM
QUOTE (MattR @ Nov 15 2005, 01:27 PM) |
Dont seatbelts go bad after a while? Why not invest in new belts? |
After 30 years of exposure to UV light, unrolling and rolling, getting closed in the door, the seatbelts are almost certainly compromised. Unless you are going for the concours deal, you want new seatbelts, or at least newer. Only problem with the salvage yard is you don't know what those seatbelts have been through.
DougC
Nov 15 2005, 03:44 PM
Right, this is why I was considering new aftermarket 3 points.. doesn't some one make them? Corbeau I think I saw somewhere.
Doug C
Midtowner
Nov 15 2005, 05:20 PM
fiid
Nov 15 2005, 05:28 PM
Do you like them? Do they fit on the stock mounting points? DO you ahve pictures of the install?
Thanks In Advance
GeorgeRud
Nov 15 2005, 09:07 PM
Are your old belts the fixed ones or retractables. If they are retractable, the 924 belts work well. If it's the early, nonretractable ones, the kit from AA works quite well.
banksyinoz
Nov 16 2005, 02:40 AM
not sure what model mine are from but there vw (its stamped on the buckles) and they fit on like factory, they were new about 2 years ago thats all i know
brownaar
Nov 16 2005, 06:00 AM
www.peparts.com has a replacement that is somewhat less than stock. I have one and it is a nice unit. It did not come with the silver diverter piece that mounts with the reel. You could probably get them to make some with these pieces if you contact them.
fiid
Nov 16 2005, 11:32 AM
Are there any DOT DMVSS-beaurocrat enabled five point harnesses available?
I know Schloth (sp?) (
) has four point retractable belts that are approved for street use... but that's not the same thing is it
blitZ
Nov 17 2005, 05:02 PM
QUOTE (fiid @ Nov 15 2005, 03:28 PM) |
Thanks In Advance |
I'd like to know more about these also. Which model did you get and did you use your existing latch or buy a new one?
Thanks
Midtowner
Nov 17 2005, 05:37 PM
I'll post pics of the install tonight. I also have to look up what model I purchased.
Midtowner
Nov 17 2005, 09:34 PM
Okay, here we go: I ordered two 3-Point Retractable, Black seatbelts $159.90 (Part #WSCH324-1000-Black) and two Hardware kits #1 $0.00 (Part # FHD-1046-1) from www.gotbelts.com. Total with ground shipping ws $169.72.
My goal was to use the new belts and reels using the original hardware. Doing so required cutting the belt to proper length, looping the old hardware onto the new belt, then sewing back up using hardcore thick thread. The retraction units are the same size as the originals and fit nicely behind the backpad. I took the following pictures to keep track of how all the parts fit together.
Midtowner
Nov 17 2005, 09:35 PM
Old Reel
Midtowner
Backside of old reel.
Midtowner
Nov 17 2005, 09:36 PM
Upper anchor, old belt.
Midtowner
Lower Anchor...
Midtowner
Nov 17 2005, 09:37 PM
New Reels with old hardware...
Midtowner
pic...
Midtowner
Nov 17 2005, 09:39 PM
Sorry, but I didn't take pictures of the new belts mounted behind the backpad because installation is the reverse of removal. This is an easy project. I took my time over two evenings. Best of luck!
fiid
Nov 17 2005, 09:42 PM
Would it be a problem to use the hardware they supply, asides from the looks? I don't have the balls to try sewing up a seatbelt.
Midtowner
One more pic. Check out the tag. May help with identification. Have a great day!
Midtowner
Nov 17 2005, 09:47 PM
Yeah, I know what you are saying about taking apart seatbelts. Besides being ugly, the inboard part of the new belts (I call it the female end) are too long making the anchor point too high off your hip when seated - not safe IMHO. Even then, you need to use a small heat gun to warp the plastic housing to fit around the contour of the seat and center seat pad. Again, I went hardcore on re-sewing the belt using the same sewing pattern. You can see this pattern in the last picture.
lapuwali
Dec 29 2005, 07:52 PM
Digging up an old thread.
The place Midtowner got his belts from have some other belts available that may be more suitable than the ones he got (which may not have been available, then).
The place is also called SeatBeltPros.com, they seem to use both domain names, and are actually a Yahoo! Store (yeah, irrelevant detail, I work in the biz, so...)
They have three-point belts with chromed aircraft style buckles as commonly seen on cars from the early 70s. These belts are adjustable at the buckle end, so his very good objection to the length of the buckle piece being too long is no longer an issue. They have belts that are both retractable into reels or fixed, like early stock belts. They also have two lengths of the non-adjustable style buckle, 12" and 20". The 20" does look way too long for a 914. The 12" is probably about right.
My new-to-me FIAT has moldy old belts in it, so I'm replacing them, and I'll be getting a set from this place myself. For the 914, I'll probably get a six-point harness from a racing shop.
fiid
Dec 30 2005, 04:22 AM
6 point belts aren't street legal though - isn't that correct? Are you just going to chance it?
Mugs914
Dec 30 2005, 10:58 AM
I've never had any legal problems with five-points. Back when I drove my race cars to work every day (Not that long ago, really...) I got pulled up a couple of times by Chippies that saw the stock belt hanging. One guy says "I pulled you over because I thought you weren't wearing wour seat belt but you're bolted in there pretty damn good, aren't you?" and let me go with a big grin and "Have a great day".
I know five points aren't DOT legal, but I don't think the average cop is going to pick that particular nit.
Of course if you're attitude asks him to...
Katmanken
Dec 30 2005, 12:10 PM
Hope ya used the right sewing pattern and the right thread....
There is a specific pattern to the sewing that the Government spent a lotta time and money on to develop for pilots and it was picked up by the seatbelt manufacturers....
Somewheres there is a MIL Spec on it....
Ken
