just tossing aroud the idea of rebuilding the tranny while we have it out....
First...where does a 904 main come from
and what gears should be used with a stock 3.0
LSD..opinions
steve
QUOTE (Racer Chris @ Nov 17 2005, 04:15 PM) |
I welded an "I" gear onto my mainshaft after cutting the "F" gear off. Probably a whole lot cheaper than a 904 mainshaft if you don't need to keep changing second gear ratios. |
QUOTE (bondo @ Nov 17 2005, 04:48 PM) | ||
How did you do that? I tried to do some machining on the shafts in an early experiment of doing something similar. Carbide bits would just scratch them. |
QUOTE (bondo @ Nov 17 2005, 06:48 PM) |
QUOTE (Aaron Cox @ Nov 17 2005, 06:56 PM) |
what are your new ratios? |
QUOTE (Racer Chris @ Nov 17 2005, 05:00 PM) | ||
A,I,M,Q,V for an engine with 8000+ redline and about 180hp. |
QUOTE (Racer Chris @ Nov 17 2005, 04:57 PM) |
Now I wish I had taken pictures. |
QUOTE (sixnotfour @ Nov 17 2005, 07:41 PM) |
On pelican some where there is a thread with a "How to change 901 second gear" by machining and welding. By Grady Clay I think. Old School get er done |
QUOTE |
wow. v for 5th pretty short. whats 8000rpm with your tires in 5th? little over 95? 100? |
QUOTE (J P Stein @ Nov 17 2005, 07:12 PM) |
For 1st: AA, B or C. B is about unobtanium. Ask AAron C will run you 3-400 from Otto...more from power House. A 'B' cost me 400 for 2nd: GA. stock 914/6 mainshaft....they can be found, but it may take some time. I got one relatively cheep. Thas all I know. I have no problem with the rest of the gear ratios. With more torque than I, you shouldn't either.....IMO BTW, I popped for a Guard TB diff bout an hour ago. 1200. |
