Tman914
Nov 19 2005, 01:56 AM
swaping out engine from a 1.8 to 2.0 what do I need to know about
wireing and relays ect: Its a 1974 - 914
Tman914
qa1142
Nov 19 2005, 08:35 AM
I'm doing this swap this winter. I'll let you know as I go, but...
you need entire d-jet with matching parts and harness. If everything works first time plugged in
I should just have to add the relays to empty slots in relay board and
Brad's site
http://members.rennlist.com/pbanders/ Is very helpful
Wish us both luck
DNHunt
Nov 19 2005, 08:37 AM
We need a little more info. Are the engines factory fuel injected? What are you using for exhaust?
Dave
Mueller
Nov 19 2005, 09:39 AM
I'd just swap the engine and install the L-Jet on the 2.0...use the 2.0 runners and the 1.8 plenum, some tweaking of the runners will have to be done to line them up, but it works....
Bleyseng
Nov 19 2005, 09:55 AM
You can install the Ljet or Djet as they both work fine and are "plug and play" if all the componets are in working order.
