cdmcse
Nov 19 2005, 02:27 PM
I've got a loud ticking sound coming from my engine, and I'd thought it was an exhaust leak. So I finally got around to installing all new exhaust and intake gaskets today. I made sure they fit with no leaks. It did solve one of my problems which was backfire during deceleration. But the ticking remains.
At this point it sounds to me like it is louder on the top of the engine than the bottom. This engine is a 1.8L with a recent rebuild (by unkown parties, but it looks clean). Valves are adjusted and make no change to the sound (i've adjusted them several times now). At this point I'm thinking maybe a lifter is going south, or could it be a broken piston ring?
Help from all the Gurus is greatly appreciated.
cdmcse
Nov 19 2005, 02:29 PM
Oh and it feels somewhat underpowered. Compression check revealed 130-140psi across the board. New plugs, wires, etc, etc, etc.
Trekkor
Nov 19 2005, 02:41 PM
Have you ever done any work to your motor using chopsticks?
Sorry...
KT
jimtab
Nov 19 2005, 05:53 PM
QUOTE (trekkor @ Nov 19 2005, 12:41 PM) |
Sorry...
KT |
Now that's just mean....I approve tho.....
Mark Henry
Nov 19 2005, 06:15 PM
Oh my lord...a real answer
could be several things, here's a couple.
Bad rod bearing...it will get worse and it will be louder at WOT
Loose rivets on the cam gear...more of a rat-a-tat-tat sound
Lifters...at least this something most can check. Pull the rockers and P/R tubes and you can remove the lifters. One at a time, keep them in order.
Piston ring...But you should have low compression on one cylinder.
Was it a re-ring or new P&C's? I've seen guys break a jug (and the ring) from not cleaning out the lands proper.
Or a tick / whistle / squeaking noise.... blown head gasket.
cdmcse
Nov 19 2005, 08:27 PM
I looked for chopsticks, but I could not find any.
The best description of the sound I can offer is it sounds like if you tapped a wrench on the case, very rythmic. It definately does not get louder under load, it just gets faster with RPM until the engine drowns it out. When driving in the car I can only hear it when I am stopped at idle.
Ferg
Nov 19 2005, 08:35 PM
I have a fuel injector that is making the same sound, or at least I think it's a injector. Hopefully it's not a internal sound that went away once the injector was unplugged. Anyhow I traced the sound to a area, once i unpluged that injector with the motor idling, on the cyclinder the noise seemed to be coming from, it stopped. That is after I did all of the above mentioned. I talked to someone else and they agreed the injectors can make a very loud ticking sound.
Ferg.
Rand
Nov 19 2005, 11:44 PM
Don't forget to check here:
Rand
Nov 19 2005, 11:55 PM
Never mind... I see your signature says '72. The air injection ports are just on the '75 and '76 cars I think. But if one of those holes opens up it will cause the symptoms you described.
cdmcse
Nov 20 2005, 10:56 AM
It has carbs so fuel injectors wouldn't be it. I didn't see any of those smog ports on the heads.
Thanks for the ideas, and keep 'em comin. It looks like I'm probably heading for a partial tear down anyway.
Mark Henry
Nov 20 2005, 11:00 AM
Could be somrthing as simple as the fan hitting the shroud...but thats more of a scraping sound.
Check eveything before you tear into her.
brp914
Nov 20 2005, 12:12 PM
for a couple weeks up until mine dropped a valve seat it made a ticking sound. Coincidently, that happened just as I pulled into my driveway coming home from work. It went from tick tick to clank clank - awful sound.
'nother time I had just built the engine. needed a -4 cam gear but oem was nla, so I used an aftermarket. after 200miles the engine was making racket. Oil was full of sparkly stuff. took engine apart - gear was trashed.
but, there are so many possibilities, and not all of 'em bad. If me, I'd check valve adj., torque plugs, check oil level (Is oil light on at idle w/ warm engine?). Lastly, get AAA+ and drive it.
Aaron Cox
Nov 20 2005, 12:14 PM
QUOTE (brp914 @ Nov 20 2005, 11:12 AM) |
but, there are so many possibilities, and not all of 'em bad. If me, I'd check valve adj., torque plugs, check oil level (Is oil light on at idle w/ warm engine?). Lastly, get AAA+ and drive it. |
was your case alignbored?
there are different sizes of gears..... could be why your cam gear was toasted...
dlo914
Nov 20 2005, 12:20 PM
QUOTE (brp914 @ Nov 20 2005, 10:12 AM) |
dont remind me of that time...she hasnt run since
brp914
Nov 20 2005, 12:33 PM
QUOTE |
was your case alignbored? |
no, case was brand new - NOS ('bout 5 yrs ago)
QUOTE |
there are different sizes of gears..... could be why your cam gear was toasted... |
right, needed -4 for proper backlash w/crank gear. aftermarket -4 was not made of alum. - grey - not sure what. Put engine back together with oem -3. It complained for a while, but I guess machined itself in-situ and is now ok.
