sk8kat1
Nov 21 2005, 11:23 AM
I finally got my teener but while " getting familiar " with my new baby I orginily found that I kept nicking 2nd -- So I was going to install the heavy duty springs to help w/ this .. but then the more I drove it I noticed that occasionaly when I shift into 1st it grinds at a dead stop ?!
--I have noticed that from what I understand is that it should idle about 900-1000 rpm -- mine is idleing closer to 12-1300 rpm -- is this the issue ... or just a part of it ....
thanks for te help
mike
tat2dphreak
Nov 21 2005, 11:28 AM
prolly just needs new bushings... and a clutch adjustment.
idle- FI or carbs?
sk8kat1
Nov 21 2005, 12:00 PM
'73 2.0 FI
I asked the guy I bought it from .. actually off here .. he had said that he replaced the bushings like a year ago .. ball cup and the firewall busshing ?
sk8kat1
Nov 21 2005, 12:01 PM
...how hard are clutch adjustments?
blitZ
Nov 21 2005, 12:04 PM
I had a similar problem upon receiving mine a few months ago. If the bushing have been replaced, check the clutch adjustment as suggested and/or replace the clutch cable. The replacement resolved my problems. Try the cheaper solutions first.
shaggy
Nov 21 2005, 01:40 PM
adjusting the clutch is easy enough for me to do it and i miss threaded an oil filter
all you do it get under the car and find the throw out bearing on the pass. side of the tranny at the ass of the car
youll see some thing holding the clutch cable to the arm of the throw out bearing
i dont know what yours will be like but on mine i replaces the stock plastic part with a 7mm wing nut thing made for the vw beatle ($.98 at FLAPS)
then i just tightened it until it was stiff and then checked it at the pedal
there should be .75'' of play
when i did mine it was right on the first shot i didnt measure it or anything i just felt it with my foot
when you do this you also wanna check the firewall to make sure that the clutch cable hasnt chewed its way down the wall
if that has happened i have no idea what to do
hope that helps
-shag
bd1308
Nov 21 2005, 01:41 PM
QUOTE (shaggy @ Nov 21 2005, 01:40 PM) |
adjusting the clutch is easy enough for me to do it and i miss threaded an oil filter |
r_towle
Nov 21 2005, 02:20 PM
In the getting to know your car phase......
Change the tranny oil...
your car will shift better with new fluid.
Check all the adjustments to your shifter...it could be mis adjusted and between that, the clutch adjustment, and new fluid...it will make alot of difference...
Rich
