Nickm1
Nov 21 2005, 11:40 AM
I put my joints together without any problems they just fell into place. now when I try to wiggle it they don't move. I think I put it in wrong and I can't get it to come apart anymore. Any tricks or anything I can do.
Bartlett 914
Nov 21 2005, 12:03 PM
If they went together easily, they will come apart easily. Do not force. You have assembled them wrong. This is easy to do. I think you have either the ball retainer in backwards or the bearings are in the wrong locations. I can't remember exactly.
Mark Henry
Nov 21 2005, 12:32 PM
It will come apart
Before you do take it apart mark it with a marker, the turn it one grove
Mark
How many Marks is that
IronHillRestorations
Nov 21 2005, 12:33 PM
The center "hub" and the outer ring must be assembled properly, or you'll end up with what you've got.
You should be able to push the hub one direction and the outer ring in the opposite direction, to get it back apart. You might have to try in several different locations around the perimeter of the CV, but it will eventually come apart.
Believe me, you aren't the first one to have this problem. The first time I fooled with my CV's, some 25 years ago, I had the same problem, and the last time I took some apart I almost did it too. Fortunately, I've dealt with more new ones that I haven't had to take apart!
