Full Version: Anyone know who makes this harness bar?
neo914-6
Also need to know where to purchase.
JoeSharp
There are no markings on the bar.
:PERMAGRIN: Joe
sj914
J P Stein
That bar positions the belts way too high.
Aaron Cox
The previous owner of joes car said it was made in somewhere in huntington beach.... i think is what he said.
ironically, joe lives there too.
i wanted to make one with 2 humps..one over each headrest.
Allan
QUOTE (Aaron Cox @ Nov 22 2005, 08:37 AM)
Be a bitch to clean the back window.
Aaron Cox
QUOTE (Headrage @ Nov 22 2005, 09:42 AM)
Allan
QUOTE (Aaron Cox @ Nov 22 2005, 08:44 AM)
Still gotta get behind that bar...
Aaron Cox
QUOTE (Headrage @ Nov 22 2005, 10:02 AM)
bar is not resting on the window either... plenty of room for a rag. poke.gif
greg.treadway
Cool bar. I also think it had to be a custom job though. I have not seen one before.
J P Stein
Allan
QUOTE (Aaron Cox @ Nov 22 2005, 09:04 AM)
Aaron Cox
QUOTE (Headrage @ Nov 22 2005, 10:21 AM)
go outside?
Allan
QUOTE (Aaron Cox @ Nov 22 2005, 09:26 AM)
go outside?
Aaron Cox
QUOTE (Headrage @ Nov 22 2005, 10:36 AM)
go outside?
how is that point relavent? i dont wash cars inside.....getting dizzy
Allan
QUOTE (Aaron Cox @ Nov 22 2005, 09:40 AM)
go outside?
.....getting dizzy
icon8.gif I'm done...
Aaron Cox
QUOTE (Headrage @ Nov 22 2005, 10:45 AM)
go outside?
.....getting dizzy
you sure?
so ideally, the harness bar, should be barely above the backpad? say like 1" or so?
lagunero
QUOTE (Aaron Cox @ Nov 22 2005, 11:45 AM)
go outside?
.....getting dizzy
you sure?
look! a maze!
1973914
Three things horribly wrong with that setup
1. The belts are attached directly to it. This is not correct unless it is part of a full cage. If the bar is connect between the two upper seatbelt holes, it is not sufficient. Unless part of a full cage, you cannot hook the belt to it. That is why they call them harness GUIDE bars...
2. If this is for a street car, then you are asking for a serious head injury with the bar positioned there. Front or rear collision (or rollover) will subject occupants to significantly higher risk of injury with those bars there. Belts stretch and occupants move at significant G loads.
3. Location of restraint is incorrect. Belts should approach the shoulder from behind at no more than a 10 degree angle. Raised up high like that, the occupant would be allowed to travel up the belts in the case of a rollover and placed in contact with the bar or with the roof it it stays attached or the road/tree/gravel/whatever if the roof comes off.
At least you will be able to get at the window to clean your brains off! laugh.gif
