Hey,
OK. I am doing a swap with the front end of my '72 914. Can I use the existing crossbrace inbetween the 911 a-arms?
Chris
QUOTE (ChicagoChris @ Nov 22 2005, 09:29 PM) |
Thanks Aaron...how many wheels are you selling in the 15 inch size? Chris |
QUOTE (Aaron Cox @ Nov 22 2005, 09:25 PM) |
yes |
QUOTE (SirAndy @ Nov 22 2005, 08:39 PM) |
if your 911 suspension has the aluminum cross-member i highly recommend using the 914 steel one instead ... Andy |
QUOTE (Headrage @ Nov 23 2005, 06:07 AM) | ||
How come? |
How come? |
QUOTE (rdauenhauer @ Nov 23 2005, 09:50 AM) |
Under what conditions does the "FLEXING" occur? |
QUOTE (Rough_Rider @ Nov 23 2005, 10:25 AM) |
Minor Hijack This cross brace is at the back of the A-arms, correct? Is there any advantages to installing bracing between the front mounting points? |
QUOTE (Aaron Cox @ Nov 23 2005, 10:26 AM) | ||
thats a solid mount on the tub. id see no reason |
QUOTE (brant @ Nov 23 2005, 10:31 AM) | ||||
Unless the tub is cut away in some manner that might weaken the points... ie: fuel cell, oil cooler, or what not. |
QUOTE (Rough_Rider @ Nov 23 2005, 10:37 AM) |
QUOTE (Aaron Cox @ Nov 23 2005, 10:39 AM) |
uh you posted that, its answered and the you post again LOL |
QUOTE (SirAndy @ Nov 23 2005, 09:18 AM) | ||
like me in the car, up on the lift, at HPH, bleeding the brakes, brad asking me to turn the front wheels to the other side (of course wheels were off) and him yelling: WTF? you could see the aluminium cross member flex (twist), right then and there, no load on it whatsoever ... that's why i went back to the steel cross member. maybe i got a bad one, maybe not. i wasn't going to take any chances. just a few ounces of weightsavings at a point where weight has the least impact (close to the ground) ... i'd rather be on the save side on this one. but hey, i'm sure you got *PLENTY* of "imperical evidence" to prove me and brad wrong! right? Andy |
QUOTE (andys @ Nov 23 2005, 11:44 AM) |
Maybe there's more there than meets the eye? |
