vesnyder
Nov 23 2005, 06:22 AM
I removed the fuel tank last night to replace it and purchased a sway bar to install while I have it removed. Also going to install a 19mm master brake cylinder while I have access to the brake fluid feed lines and some general clean-up and POR-15 some surface rust spots - anything else I should do while I am in there and have the fuel tank removed?? Messing around with teh fuel and draining the tank is not something I want to do twice?
Thanks
Trekkor
Nov 23 2005, 07:36 AM
If you were thinking of replacing the fuel lines up the tunnel now would be the time.
KT
J P Stein
Nov 23 2005, 11:26 AM
Are you feeling feverish? It's begining to sound like a case of DWD
sean_v8_914
Nov 23 2005, 11:39 AM
relocate teh fuel pump to the front
check your defrost/ventilation blower
windshield hasher system
sean_v8_914
Nov 23 2005, 11:40 AM
I just did all this stuff, here's how
http://www.914world.com/specs/tech_fuelline...f7071cbbf310d4dI ran a guide wire through my lines, then removed teh plastic while keeping the guide wire in place
