Mostly, spend some money
Didja ever notice how easy that is to do?
I have some raised spindle struts that have been waiting to go on.
The trans is gonna get 2 new gears & a Torque Biasing differential.
I may hold off on going after my scrub radius problem as that is "just" a matter of wheels & tires up front. I've never liked the way my car has reacted to same size wheels & tires at both ends, but I may wait to see how it reacts to the TB diff.
I'm also looking at softer front T-bars & more roll stiffness there.
Then......maybe a rear AR bar...depending on what happens
up front.....which would require (I think) softer rear springs.
Does this sound like I'm thrashing around in the dark? It should.
I have no recipe to follow. No one around here runs a 914 as edgy as mine so good information is hard to find. No one on the club volunteers much BTDT either.
I sucked on Greg Fordahl's brain for about 10-15 minutes......coulda used another hour or more. He's on a different level and it's hard to keep up
He did warn me off some tires I was going for....that saved some pain.
As a side note, he mentioned they have gone to EFI on their 2.8L 914 AX car and gained 30ft/lbs of torque across the dyno chart & 10 hp. The SCCA leagalized twin plug heads for the class just after they got it all buttoned up & tuned....ouch.
If I get bored, I can color sand & polish some paint.
