toon1
Nov 23 2005, 11:51 PM
Is there a way to make a setup to check the fuel pressure on the pump before installing it in the car?
r_towle
Nov 23 2005, 11:59 PM
put a line with a fuel pressure guage in the middle...
Run it from the d port to a fuel pressure regulator and back to your gas can.
Run another line from your gas can to the s port on the pump.
The power is 12V pos and ground...
Rich
toon1
Nov 24 2005, 09:45 AM
the pressure gauge goes between the pump and the press. regulator?
SLITS
Nov 24 2005, 10:21 AM
QUOTE (toon1 @ Nov 24 2005, 08:45 AM) |
the pressure gauge goes between the pump and the press. regulator? |
Yes
Cap'n Krusty
QUOTE (toon1 @ Nov 24 2005, 07:45 AM) |
How else will it read the pressure? The Cap'n
toon1
Nov 24 2005, 12:27 PM
Just wanted to make sure, thank's guy's.
toon1
Nov 26 2005, 06:20 PM
I made the setup and checked the pump, got good pressure but I was getting fuel drizzling out of the R port. Is that normal?
srb7f
Nov 26 2005, 10:45 PM
Speaking from past experience here, be very careful when attaching electrical wires to a fuel pump testing contraption with fuel drizzling out...all it takes is one spark to create a garage fire for you. I was lucky and had a fire extinguisher in the trunk, but instead of messing with this, I'd suggest just hooking up the hoses and attaching the fuel pressure gauge to the fuel ring. Steve
