Gilbert914
Nov 26 2005, 06:27 PM
and a good wash, here's a pic of my car in action last weekend in yorkshire, england
oh and i need some new fog lenses/grilles and front valance after an incident with some cones
check out the front tyre you can see it's been working hard
grasshopper
Nov 26 2005, 07:32 PM
look like some sway bars are in need
looks good though. other than the little accident
hmeeder
Nov 26 2005, 07:44 PM
I would suggest a front sway. 19mm would be fine if you don't go crazy with the rest of the suspension.
Do brits carve their cones out solid rubber? I think you'll find that if they are hollowed out, they will be a bit more compliant.
r_towle
Nov 26 2005, 08:16 PM
yup...sway bar might help.....
What kind of cone was that???
Or is that alot of bondo that decided to move along...
Rich
dlo914
Nov 26 2005, 08:59 PM
to replace that front valance you should go w/ an LE valance. they're only $70 from
Performance Products
jhadler
Nov 26 2005, 09:09 PM
I'd say get a 19mm front bar, and call it good for a start.
As for the cone strike? Was it cold out then? Cold cones have a tendancy to inflict some pain on body work. Less compliant, and sometimes they even shatter...
-Josh2
jhadler
Nov 26 2005, 09:11 PM
Daniel, can you send me larger size version of your avatar? I need a fll sized version for my garage...
-Josh2
dlo914
Nov 26 2005, 09:28 PM
here ya go:
Gilbert914
Nov 27 2005, 06:48 AM
QUOTE (dlo914 @ Nov 26 2005, 06:59 PM) |
to replace that front valance you should go w/ an LE valance. they're only $70 from Performance Products |
I'm with you on that one Daniel, standard steel ones retail for over $400 here in the UK
, i think i can get the LE version for around $110 which is probably about the same with shiping and tax if i ordered from Perfomance Products.
It was quite cold out there, something like 5c, so i guess this hardened the cone somewhat, oh and combined with the speed i was travelling
mikelsr
Nov 27 2005, 10:55 AM
I had the same problem as far as needing a sway bar on my teener but I already had one (it just wasn't adjusted very well). Here is a pic of mine before I adjusted it. It is a 19mm weltmeister.
After I adjusted it (3" from the end) I had one of the guys tell me that I was lifting my front wheel when making a hard turn. I was amazed at how it affected my teener. To be honest I think it was a very good learning experience for me to see how much it affected the handling of the car.
Mike
Gilbert914
Nov 27 2005, 03:33 PM
QUOTE (mikelsr @ Nov 27 2005, 08:55 AM) |
After I adjusted it (3" from the end) I had one of the guys tell me that I was lifting my front wheel when making a hard turn. |
nice!
that's good information thanks, just shows that adjustment is just as crucial as fitting one.
lovely looking car as well Mike
mikelsr
Nov 27 2005, 04:08 PM
Thanks Darren and I also think you have a great looking car. Good luck on getting the front (and rear) set up.
Mike
Brando
Nov 27 2005, 04:35 PM
Wow, only $70 for that LE valence? F/G or steel? That's worth it!
dlo914
Nov 27 2005, 04:50 PM
QUOTE (Brando @ Nov 27 2005, 02:35 PM) |
Wow, only $70 for that LE valence? F/G or steel? That's worth it! |
fiberglass
the lighter the better!
Aaron Cox
morphenspectra on the board now makes wicked FG LE spoilers....
