Full Version: I think I have a head leak
Allan
My car has the faint dreadful puffing sound coming from the right side of the motor. I stuck my hand up around the exhaust and could feel air blowing in a steady stream. It wasn't hot air or coming out in a quick puff, puff, puff like I would think escaping exhaust gasses would be.
When there is a load on the motor when accelerating the exhaust note becomes very deep and loud. Like the sound of a Harley with open pipes. Once up to speed it gets really quite.
Am I doomed???
J P Stein
I had this happen at an AX once. The plug for the air injection
port fell out. I laid under the car while the engine was running to find it.....Not too bright but effective confused24.gif
Porsche Rescue
Is it a 2.7? If so, JP may have diagnosed it. Could also be an ordinary exhuast leak at the head. If you have headers you should be able to look up there and see black where the leak is. A lot harder to see if you have heat exchangers.
Noise under load, quieter on slack throttle, sounds like exhaust, not head.
Allan
What's the best way to validate my worst fear???
brp914
hows about doing a compression check. Also, might want to take off the valve covers and make sure those head studs are snug. Especially the lowers. Not a real happy place on 2.7's. good luck
r_towle
a compresion test will give you a rough idea...a leak down test will give you much more detail...
Rich
Allan
Put the car up on jack stands and crawled around for awhile hoping to find and obvious source of an exhaust leak but couldn't see anything based on my very limited experience. I did notice that one of the air injection ports was plugged with what looks like a 6mm bolt with the head sheared off. dry.gif
Allan
I know the picture sucks. I'll try and get better ones when I get the car on a lift. I also noticed that on 2 of the exhaust studs had a bushing/spacer looking thing under the nut. Any clue?
echocanyons
Looks like the exhaust studs are for the thick manifolds with a spacer to take up the slack.
Allan
QUOTE (echocanyons @ Nov 27 2005, 03:12 PM)
Only on 2 of them?
echocanyons
confused24.gif maybe teh others were repladced with the proper ones
Allan
Okay, started the car and climbed under it and could definitely hear a leak but couldn't see or feel a thing. headbang.gif
J P Stein
In the pic:
A spacer on a stud like that has to be thick....diameterwise.
Tubing will deform quickly and allow the nut to loosen...gasket starts leakin'....yada. Note to cobblers: you're better off with a stack of washers. rolleyes.gif
To the upper right of your lower box....got it? biggrin.gif There's a glob of black gooey lookin shittage. If the head starts leakin, that's where it will show and in that form.....
I would put it in the air. Pull the headers. Replace the studs with the proper ones (this can be a real stinker as the old ones like to break.). The old gaskets will show signs of leakage if that is the problem......IF they seem good.
Drain the oil. Pop off the lower cam covers. Check the head bolts for tightness (if none fall out in your lap.)
Warm?. Indeed. It's a quicky, in and out.....
Good luck.
