kdfoust
Nov 26 2005, 07:29 PM
Hey.
I was putting holes in the car to route my oil lines today. I'm a little concerned about the bend radius at the location where the oil line crosses from under the rocker through the longitudnal and into the cockpit. After looking at it for a few minutes it occured to me that I could either cut or reshape the end of the long into a shape that roughly follows the blue line on the digipic and tapers to almost nothing at the end of the long. That would give me a much better bend radius and maybe avoid having to put fittings in the hoses to make the turn. I am running -12 and -16 lines. The -12 looks pretty marginal so I'm assuming the -16 isn't going to make the turn at all.
Anybody done this or have any input?
Later,
Kevin
Aaron Cox
Nov 26 2005, 07:31 PM
BTDT with -10....
my tub entry is a bit wider, so it can be a longer, smoother bend....
jeff
Nov 26 2005, 07:33 PM
Where in so -cal are u? close to thousand oaks?
kdfoust
Nov 27 2005, 12:52 AM
QUOTE (jeff @ Nov 26 2005, 05:33 PM) |
Where in so -cal are u? close to thousand oaks? |
No. I'm in South OC.
Later,
Kevin
kdfoust
Nov 27 2005, 03:55 PM
Let ask this a different way. What's this piece of sheetmetal for?
Aaron Cox
Nov 27 2005, 04:48 PM
its just a sill support. i eliminated the one on the otherside, and welded in a new brace i made
736conver
Nov 27 2005, 04:58 PM
What about putting a fitting to made the turn. Kevin I have two -16 fittings one is a male to male 90 degree and the other is a 145 degree male to male.
If these could help you shoot me a pm or email and they are yours.
kdfoust
Nov 27 2005, 07:30 PM
QUOTE (736conver @ Nov 27 2005, 02:58 PM) |
What about putting a fitting to made the turn. Kevin I have two -16 fittings one is a male to male 90 degree and the other is a 145 degree male to male. If these could help you shoot me a pm or email and they are yours. |
Hey Brian:
Thanks for the offer of the fittings! Unfortunately, I've got a bunch of fittings sitting around here. So many that I expect to get a Christmas card from Earl's this year.
I'm trying to totally weasel out of using fittings to get around that corner. Worst case I'll put in a -16 90 to get around there and let the -12 make the bend. After looking at it some more I think the -12 will get around okay with a minor bit of cutting.
Later,
Kevin
kdfoust
Nov 27 2005, 07:33 PM
Now I really have to know what that thing is. I'm not buying that its a door sill support. This is a sill support...
kdfoust
Nov 27 2005, 07:35 PM
This on the other hand looks awfully fancy to be just a sill support... I've already cut the sill support away that was on the end of the long.
John
Nov 27 2005, 08:51 PM
To the best of my memory, that is just an empty box. I believe I have seen them removed showing that they are empty, but I don't have any pics backing this up.
If you remove the box, you should just see the outer long. I agree in thinking that it is a support for the sill.
I'm planning on running my oil lines INSIDE my longs. (no heat)
Brando
Nov 27 2005, 09:20 PM
Those are the holes I will be using when running my oel lines front to rear. Maybe open them up if needed.
kdfoust
Nov 28 2005, 12:47 AM
QUOTE (JOHNMAN @ Nov 27 2005, 06:51 PM) |
I'm planning on running my oil lines INSIDE my longs. (no heat) |
Yeah, I drilled a hole in it to have a look. It is hollow. It just seems like an awful lot to go through for a sill support compared to the other supports which makes me wonder if something a little more interesting is going here - like some structural.
Kevin
Aaron Cox
Nov 28 2005, 10:23 AM
and whats funny is, the left and right arent the same.
the one you are playing with is already "bent" for factory oil lines, and the other side is a straight hollow box.
structure? probably just jelps the pivot for the door strong....
