QUOTE (scotty b @ Nov 26 2005, 05:49 PM) |
Did you use a Porsche harness or a VW harness?? Seatbelt interlock killswitcharoo thingy ma bob needs to be hooked up or jumped. |
QUOTE (grasshopper @ Nov 26 2005, 06:51 PM) | ||
it came out of a 74 914..... so everything this guy cut needs to be reconnected??? |
QUOTE (Aaron Cox @ Nov 26 2005, 05:52 PM) | ||||
or bypassed.... |
QUOTE (SirAndy @ Nov 26 2005, 06:04 PM) | ||
you went through all the trouble of installing a new main harness and it was already cut in pieces ??? |
QUOTE (r_towle @ Nov 26 2005, 06:09 PM) |
seems in our investigation of the seat belt relay wiring logic...there is only a need for the two large yellow wires to be connected/jumped... Start at the beginning of the circuit. At the ignition switch...do you have power going to the switch? If so, in the run position do you have power still going to the switch, and then leaving the switch? Follow the power to find where it it stopped or shorted. I bet your ignition switch may be to blame...probably some differences in that switch... Rich |
