olav
Nov 27 2005, 01:20 PM
Allan
Nov 27 2005, 01:22 PM
Just take a big assed saw and hack off two cylinders then seal with J-B Weld.
Aaron Cox
Nov 27 2005, 01:23 PM
jr91472
Nov 27 2005, 01:43 PM
$19K
sixnotfour
Nov 27 2005, 01:52 PM
I bought a 75 that had a 2.2-6 motor that spun a rod bearing, So I took out all the conversion pieces put a 1.8 T-4 back in it and sold it.
Now it has a 2.5-6
4-6-4- back to SIX
Bleyseng
Nov 27 2005, 01:58 PM
Olav,
I take that 3.2 core motor off your hands when you install the 1.8l.
Long Prong
Nov 27 2005, 02:45 PM
why dont you just stick with the /6
olav
Nov 27 2005, 03:38 PM
QUOTE (Long Prong @ Nov 27 2005, 12:45 PM) |
why dont you just stick with the /6 |
Better gas mileage?
J P Stein
Nov 27 2005, 03:51 PM
Why not shoot the moon and go for a 1.7L.....and pull a plug wire.
Dead Air
Nov 27 2005, 03:59 PM
You'll need to:
1) convert to a side shifter while you're in there.
2) find solid discs or drill out four holes for your lug studs.
3) call the scrap man to take that 6 cyl. boat anchor off your hands.
4) buy a new set of carbs.
5) find a passenger seat that slides and a new back pad.
If it has the GT flares, you'll have to shave those,too!
It could get expensive!
If your serious about it I have some 1975 bumbers that may retro fit!
PM me
qa1142
Nov 27 2005, 04:03 PM
Sell the 6 and buy two 1.8L's
One for each of us
olav
Nov 27 2005, 06:15 PM
QUOTE (Dead Air @ Nov 27 2005, 01:59 PM) |
You'll need to: 1) convert to a side shifter while you're in there. 2) find solid discs or drill out four holes for your lug studs. 3) call the scrap man to take that 6 cyl. boat anchor off your hands. 4) buy a new set of carbs. 5) find a passenger seat that slides and a new back pad. If it has the GT flares, you'll have to shave those,too!
It could get expensive! If your serious about it I have some 1975 bumbers that may retro fit! PM me |
Side shifter: check
four more to go!!
neo914-6
Nov 27 2005, 06:28 PM
With gas prices, you need to go diesel or hybrid!
GTeener
Nov 27 2005, 06:31 PM
QUOTE (neo914-6 @ Nov 27 2005, 04:28 PM) |
With gas prices, you need to go diesel or hybrid! |
Electric
John
Nov 27 2005, 08:58 PM
What size six?
Can't you just remove 2 spark plugs and Injector harnesses?
Cost = 0
sixnotfour
Nov 27 2005, 10:05 PM
Foul :overhead camshaft not allowed
pete-stevers
Nov 28 2005, 08:57 AM
i have a 1.8..... you want to pay for shipping.....
goose2
Nov 28 2005, 11:37 AM
this may be off topic, but how much would it cost to put a Chevy Vega motor in my Carrera GT? This thing has too much power.
Brett W
Nov 28 2005, 12:04 PM
Well first you will need to have custom crank made so that you cut the stock stroke down, then you will need some custom pistons with raised pins. And of course you could go with a longer rod so you can get the better rod-stroke ratio. Better go to bigger valves so you can rev higher and better springs to take advantage of the higher rpm capabilities.
Brett W
Nov 28 2005, 12:07 PM
Oh my bad you meant THAT other 1.8.
