shaggy
Nov 28 2005, 03:21 PM
im going to install a 19mm fartory front sway bar
what do i need to change my rear springs to, to make it ride flat?
i want minimal body roll but i also dont want it to be an unbearable driver
im planning on changing the shocks to bilstein sports as soon as i get up the money
id also like to lower it an inch if possible, that and id also like the stiffening kit from engman, im not sure when ill have the money but id like to
so what would y'all suggest?
Andyrew
Nov 28 2005, 03:28 PM
140 lb rear springs is the most common with a stock front bar and no rear bar.
GL
Andrew
Tobra
Nov 28 2005, 03:30 PM
The (anti-)sway bar makes the inside wheel on the corner push down harder, it seems to me you would be more likely to lift the inside rear tire without the rear bar. You would be better served putting a rear bar on than trying to control this with springs. The sway bars will not do much if you are going straight, it will ride flat already.
MattR
Nov 28 2005, 03:31 PM
I thought the stock bar was like 14mm? What 19mm bar is this? I have an aftermarket 19mm front bar with 165 progressive springs. It looks good on jackstands
MattR
Nov 28 2005, 03:33 PM
QUOTE (Tobra @ Nov 28 2005, 01:30 PM) |
The sway bars will not do much if you are going straight, it will ride flat already. |
Thats assuming the road is perfectly flat. In reality the suspension deflects a lot on the street because of bumps and imperfections.
A rear sway bar has been known to cause push (understeer) with a bigger front bar in auto cross situations.
shaggy
Nov 28 2005, 03:35 PM
its a factory sway bar off a 911sc
i dont know the year, but its a 19mm
Aaron Cox
the best and cheapest my car ever handled....
24mm sway bar...
stock torsion bars
140lb springs
stock rear sway bar......
now its
24mm sway
19mm 911 tbars
180lb springs
rear sway
soon to be
24mm sway
22mm t bars
225lb springs on threaded collars
rear sway
shaggy
Nov 28 2005, 03:38 PM
ive already ordered the bar and it has been shipped its going in on the 4th and i hope to have money for springs soon
so 140's?
where should i get em?
they are no longer available from pelican
Flat VW
Nov 28 2005, 03:40 PM
QUOTE (shaggy @ Nov 28 2005, 01:35 PM) |
i dont know the year, but its a 19mm |
I suggest you get off the site and STUDY while you are at school!
Dad
Aaron Cox
Nov 28 2005, 03:42 PM
Aaron Cox
QUOTE (Flat VW @ Nov 28 2005, 02:40 PM) |
QUOTE (shaggy @ Nov 28 2005, 01:35 PM) | its a factory sway bar off a 911sc
Dad |
B U S T E D
shaggy
we have a free period now so its ok
if i was going to buy the turbo tie rod kit from pelican
would i need 2?
or for each side?
they advertise it as 179.99 each
Aaron Cox
Nov 28 2005, 03:43 PM
QUOTE (shaggy @ Nov 28 2005, 02:35 PM) |
you bought an underbody swaybar from an SC???
wont work without the a arm mounts OFF an SC...
and not sure it mounts to a steel X member....
your hosed
Aaron Cox
Nov 28 2005, 03:44 PM
QUOTE (shaggy @ Nov 28 2005, 02:42 PM) |
would i need 2? or for each side?
they advertise it as 179.99 each |
each as in a pair of 2 tie rods
shaggy
Nov 28 2005, 03:45 PM
its not the under body one
SLITS assured me of that its the one that goes under the gas tank
shaggy
if i was gonna do turbo tie rods what else would i need besides the one kit?
Aaron Cox
Nov 28 2005, 03:46 PM
QUOTE (shaggy @ Nov 28 2005, 02:45 PM) |
SLITS assured me of that its the one that goes under the gas tank |
than it aint from an SC.
its either an H/R 19mm kit, weltmeister, or
a 76 930 18mm stock thrubody bar.....
Aaron Cox
Nov 28 2005, 03:47 PM
if i was gonna do turbo tie rods what else would i need besides the one kit? |
while your in there....
Ball Joints
A arm bushings
rack spacers - if you are lowering....
new brake lines.....
shaggy
maybe its an 18 then
he said he thought it was a 19 and its from a 911
i know that much and it goes through the body
Flat VW
Nov 28 2005, 03:48 PM
QUOTE (shaggy @ Nov 28 2005, 01:45 PM) |
A better paying job!
Dad
jd74914
Nov 28 2005, 03:53 PM
SLITS
Jim....we have a miscommunication here
The bar is either the 15?mm stock one off a 914 or whatever the size is on a '67 911 (prolly the same)
If these don't fit your needs, I won't ship it.
Aaron Cox
Nov 28 2005, 03:55 PM
QUOTE (SLITS @ Nov 28 2005, 02:53 PM) |
QUOTE (shaggy @ Nov 28 2005, 02:45 PM) | its not the under body one
If these don't fit your needs, I won't ship it. |
says on the square end of the bar ron...
914 = 15mm
early 911 13 mm iirc
SLITS
Nov 28 2005, 04:05 PM
QUOTE (Aaron Cox @ Nov 28 2005, 02:55 PM) |
QUOTE (SLITS @ Nov 28 2005, 02:53 PM) | QUOTE (shaggy @ Nov 28 2005, 02:45 PM) | its not the under body one
914 = 15mm early 911 13 mm iirc |
Crap...does that mean you actually want me to look ?
Aaron Cox
Nov 28 2005, 04:11 PM
yup
on atleast one side....
Brando
Nov 28 2005, 04:38 PM
QUOTE (Flat VW @ Nov 28 2005, 01:40 PM) |
Dad |
Go with that 19mm front bar, leave the rear springs and go with a factory rear bar. Once you've got the rear bar in you can decide if you've got oversteer or understeer and to what degree.
SLITS
Nov 28 2005, 04:42 PM
QUOTE (Brando @ Nov 28 2005, 03:38 PM) |
QUOTE (Flat VW @ Nov 28 2005, 01:40 PM) | QUOTE (shaggy @ Nov 28 2005, 01:35 PM) | its a factory sway bar off a 911sc
Dad |
Go with that 19mm front bar, leave the rear springs and go with a factory rear bar. Once you've got the rear bar in you can decide if you've got oversteer or understeer and to what degree. |
Unless he buys a whole SC front end, the underbody won't work Brandon.
Dave_Darling
Nov 28 2005, 09:46 PM
Unless you can weld, I wouldn't bother with the rear bar. You gotta weld the mounts onto the trunk floor, which may be more hassle than it's worth.
If the bar is a stock 15mm front sway bar, I'd leave the rear springs alone. See how you like the way the car handles with that setup. If you think it pushes too much, I'd consider going to 100 lb/in rear springs.
If the bar is a 19mm adjustable one, I would recommend either 100 lb/in or maybe 140 lb/in rear springs. I think the 140s get you pretty close to the limit of adjustability of the Weltmeister 19mm front bar. The 100s would probably be a better match.
If you do want to go with a rear sway bar, drop the rear spring rates down by at least one "notch".
BTW, a front sway bar will help the inside front wheel to lift, not the inside rear. That's not a bad thing in and of itself, if the overall balance of the car works out OK.
--DD
Brando
Nov 28 2005, 11:04 PM
QUOTE (SLITS @ Nov 28 2005, 02:42 PM) |
Unless he buys a whole SC front end, the underbody won't work Brandon. |
Whoops! Going off of the assumption he had an SC front end (saw mention of it).
What? I don't have class today, I can leave my reading comprehension at work.
