Rotary'14
Nov 28 2005, 09:45 PM
I am going to MegaSquirt my carbed 1.8, so I'm starting to collect some parts. I got a lead on some 1.7 d-jet stuff. Will it fit on my 1.8?
Thanks!
-Rob
Brad Roberts
Nov 28 2005, 09:54 PM
It will bolt right on. I personally would use the 1.8 runners with a 2.0 plenum.
B
McMark
Nov 28 2005, 10:10 PM
Bleyseng
No, they are different diameters with 2.0L being the largest at about 36/37mm.
Brad Roberts
Nov 28 2005, 10:15 PM
Correct, but he cant easily bolt 2.0 runners onto his engine (I factored that in
B
McMark
Nov 28 2005, 10:20 PM
Two questions going on here...
Are they the same? Nope. Aside from diameter differences, 1.7 & 1.8 have four mounting holes, 2.0 has three mounting holes.
Can you use 1.7 stuff on your 1.8? Sure, they're both four bolt manifolds.
Rotary'14
Nov 28 2005, 10:33 PM
Great info! Thanks for the fast replys. Now for question 2, are the throttle body mounting points identical between the different plenums?
-Rob
Bleyseng
Nov 28 2005, 10:40 PM
No, the 1.7,1.8 are sidedraft where the 2.0L sits on top of the plenum. The 2.0L plenum is bigger too which is gud.
Brad Roberts
Nov 28 2005, 10:57 PM
Your killing me Geoff.
QUOTE |
Yes.
B
Bleyseng
Nov 28 2005, 11:37 PM
2.0L plenum
Brad...
back to my popcorn
Bleyseng
try again
Brad Roberts
Nov 28 2005, 11:39 PM
I put a long sleeve shirt on today because I was chili. It was only 67 today.
B
Brad Roberts
Hey.. that is MY picture.
B
Bleyseng
Nov 28 2005, 11:54 PM
And this?
Brad Roberts
Nov 28 2005, 11:57 PM
Used to be my car.. but I dont recall who took the pic. I'm pretty sure you attended that event. I know I shot one pic of the OE 914Club sticker on the drivers side sail panel.
B
914werke
Nov 29 2005, 12:50 AM
Why not simply drill a coupl'a holes in the 2.0 runners? should slap right on and match the 2.0 plenum.
Im actually doing this to my 1.7 ..swapping the P&C's and heads off a 1.8 and djet induction off of a 2.0
Mueller
Nov 29 2005, 01:19 AM
1.7 small ID
1.8/2.0 same larger ID (not by much, but different than the 1.7)
the 1.8 runners will mate up to the 2.0 plenum if you bend the runners a little
Mark Henry
Nov 29 2005, 08:14 AM
QUOTE (Mueller @ Nov 29 2005, 03:19 AM) |
the 1.8 runners will mate up to the 2.0 plenum if you bend the runners a little |
You also have to cut the runners down a bit.
BTRT (been there running that)
914werke
Nov 29 2005, 07:41 PM
I didnt know the ID on the runners for the 1.8 and 2.0 were the same? Mark what do you mean "cut down"? Trim the length of the tube ends?
Bleyseng
Nov 29 2005, 08:57 PM
I think the 1.8's due to the plenum layout being a side draft TB are longer.
Hey, how's it going Rich?
Hoe gaat het??
