Full Version: D-Jet help...it was OK
sean_v8_914
2.0 D Jet, new engine. it ran fine yesterday. I changed the points with a compufire. the idle smoothed out nicely. I touched something wrong because now it hesitates past 1/2 throttle under load. below 1/2 throttle its nice. on teh fwy its fine WTF.gif
sean_v8_914
I like posts with pics
sean_v8_914
this one
swl
vacuum to the MPC? or perhaps another vacuum leak? MPC adjusts the fuel pulse for load.
BTW that is a beautiful engine.
JoeSharp
Sean: Did you do your 10 point check.
:PERMAGRIN: Joe
Allan
Don't know about the hesitation problem but where is your alternator cover?
JeffBowlsby
Are your dizzy weights sticking? One drop of 30 wt on the center felt per year is what Haynes says to do...
Bleyseng
Re-check the timing, 28-32degrees BTDC @3500rpms
Both advance and retard hoses still on?
sean_v8_914
someone show me what an alternator cover looks like please
sean_v8_914
yes Joe
thats a cheap shot, I need that knee cap
John
It sounds like a leak in the MPS or one of the hoses leading to it.
I would try checking there first. You may have inadvertently bumped a hose loose.
Is it running excessively rich or lean? Or is it just hesitating?
I had one once that wouldn't pull past 3500 RPMs to find that the coil had shot craps.
Good luck.
Gint
Hey Sean
Did you re-time after installing the pertronix?
sean_v8_914
yup, re-timed it. just checked total adv again, 29 deg. Ill go check that MPS hose again.
it does run very rich. I can smell it
Bleyseng
You unplugged the CHT and its running way rich...........
