ynotdd
Aug 20 2003, 08:24 AM
I have a 73 914 2.0. The engine has less than 1000 miles since rebuilt. I have a problem at about 3600 to 4000 rpm it falls on its face then once passed that to pulls fine. I have replaced the throttle switch, pressure sensor, injectors, points, condenser etc. problem still there all i can think of is temp sensorII or vac lines. please help. Tony:confused: :mad:
Brad Roberts
Aug 20 2003, 12:24 PM
Did they resuse the stock (probably worn out) distributor ??
I say dump the points... but I need to know if the timing mark shows up nicely when you time it..or if it is bouncing around when your trying to time it.
B
ynotdd
Aug 20 2003, 12:27 PM
the marks were solid no bouncing
Brad Roberts
Aug 20 2003, 12:29 PM
Where did this "new" pressure sensor come from ??
Dump the points.. not worth keeping them.
B
nebreitling
Aug 20 2003, 02:23 PM
i'm having these same exact symtoms -- my flat spot is at ~4600rpm. pulls great beyond that (although i cant' get it past that spot in 4th or 5th gear). MPS checks out okay, TPS seems clean enough, engine runs great otherwise. all electrical grounds cleaned. as soon as i get some time, i'm going to have a good going through of the distributor. i've been told that slop from a worn distributor shaft can cause this. as long as i'm at it, i'm going to install a crane pointless ignition. $90 on summitracing.com.
let me know if you resolve this, i'll do the same.
nathan
ynotdd
Aug 20 2003, 03:57 PM
The PS was from dont yell AA
put the old one back no change
Brad Roberts
Aug 20 2003, 06:05 PM
These issues are tough.. it could be fuel related or ignition related. I tend to believe its ignition related. You could have a bad spark plug wire or somebody could be running the fuel pump off the coil (robbing voltage for both).
B
