Nick
Dec 3 2005, 05:57 PM
I spent today installing new rear wheel bearings and that went OK I think. I left the swing arm on the car and just unbolted the rear brake calipers, but left all the lines connected. I backed out of the garage and the brake pedal went straight to the floor. Pumping didn't seem to help. I can see no leaks and the brake fluid is full. I lift the car off the ground again and had a helper step on the brakes. all the wheels locked to the point I couldn't turn them by hand. I guess the question is what should I look at next?
Nick
ClayPerrine
Dec 3 2005, 06:18 PM
Two things...
1. check the venting clearance on the rear pads.
2. Bleed the brakes.
Nick
Dec 3 2005, 06:45 PM
I should have added brakes are off and 80's 911 so I think there are no venting clearance issues. As for Bleeding I'll give that a try, but the brakes felt great on the last trip. I'm guess it is a Master Cylinder failure, but would like to do some trouble shooting before I order a new one.
Nick
Eric_Shea
Dec 3 2005, 11:19 PM
If you suspect a M/C you should check the floor around your pedal assembly. Any failure will probably show up there.
Bleyseng
Dec 4 2005, 09:17 AM
you'll see a puddle of fluid .
Dave_Darling
Dec 4 2005, 04:09 PM
To fit the calipers back over the rotors, you did have to push the brake pads back in a little ways, right?
That first press of the pedal pushed the pads against the rotor. It's perfectly normal, and is the reason that you always pump the pedal a time or two after you do any brake work.
--DD
Nick
Dec 5 2005, 10:41 PM
Pumped the brakes like crazy and it doesn't help at all.
Nick
