electrolime
Dec 5 2005, 02:37 PM
Hey, I'm fairly new to the 914 community. I just purchased a weber progressive carburetor for my 914. What all am I going to need to do to switch over from the fuel injection. All help is greatly appreciated.
Thanks
-Pat
sj914
Dec 5 2005, 02:40 PM
You'll need a low pressure, fuel pump.
Cap'n Krusty
Dec 5 2005, 02:48 PM
Hey! I get to be the first one to tell you! You'll be sorry. Trust me, it's a BIG step backwards. While dual carbs can be made to work, especially with a cam change, the Pinto carb you've selected is a known turkey. It will NEVER run well, no matter what you do. The Cap'n
rjames
Dec 5 2005, 03:08 PM
I'd be interested in buying some of your FI stuff should you go ahead with the install though....
(throttle position sensor, throttle body and injectors -if they are any good, to name a few)
bd1308
Dec 5 2005, 03:57 PM
I beg you, please don't do it.....
I did it on my 1.7, and it sucks real bad.
teh runners dont get warm enough
runs lean->ok->lean->really lean->ok->lean->lean->
DONT DO IT!
I've done the conversion myself and there is no benefit!
Seriously reconsider...
b
markb
Dec 5 2005, 05:03 PM
I holed a piston with one of those, when it leaned out on me.
DON'T DO IT!
Take the carb back & get a refund. Spend the money fixing the FI.
Dec 5 2005, 05:16 PM
QUOTE (Cap'n Krusty @ Dec 5 2005, 01:48 PM) |
Hey! I get to be the first one to tell you! You'll be sorry. Trust me, it's a BIG step backwards. While dual carbs can be made to work, especially with a cam change, the Pinto carb you've selected is a known turkey. It will NEVER run well, no matter what you do. |
with the krusty one ...
fix your FI and you'll be *much* happier ...
Andy
pfierb
Dec 5 2005, 06:36 PM
Listen to them.... from one who had carbs on my car and now has the FI back on.
JoeSharp
Dec 5 2005, 06:53 PM
Ah Don't listen to anyone but yourself. But as far as I'm conserned, the least you should do for a carbed motor is this. Oh yeah its only about $800.00.
:PERMAGRIN: Joe
bottomend
Dec 6 2005, 04:59 AM
Those are Kadrons, right? they'll work nicely on your engine and a set is around $450. But you should try to get the F.I working . It really is better.
