Question for those of you that have converted to Carrera axels ( my -85 / 915 trans)-
Do you have ‘any’ excess movement between the rear trailing arm bearing and the out side hub.
Another way to ask this question is- if you lift / jack up the rear of car, can you ‘rock’ the rear tire side to side or up and down 1 mm or more.
Mine does that even with new rear trialing arm bearings.
ANY suggestions or is this normal – which I do not believe.
Thank you!
