Aaron Cox
Dec 9 2005, 04:11 PM
Brian frenz gave me the coleman collars.....
Mueller gave me the Spring hats from coleman....
and afco sent me some springs....
its all together now
thanks to these guys !
TonyAKAVW
Dec 9 2005, 04:17 PM
You suck.
Thats awesome. I can't wait to see those installed.
-Tony
Aaron Cox
springs shipped were only 41 bucks new.....
jd74914
Dec 9 2005, 04:23 PM
QUOTE (Aaron Cox @ Dec 9 2005, 05:11 PM) |
Brian frenz gave me the coleman collars..... Mueller gave me the Spring hats from coleman....
How long are the threaded perches and and springs?
Aaron Cox
Dec 9 2005, 04:24 PM
QUOTE (jd74914 @ Dec 9 2005, 03:23 PM) |
QUOTE (Aaron Cox @ Dec 9 2005, 05:11 PM) | Brian frenz gave me the coleman collars..... Mueller gave me the Spring hats from coleman....
How long are the threaded perches and and springs? |
5" collars
8" Afco 225lb springs
jd74914
Dec 9 2005, 04:37 PM
thanks
Last Q, whats the spring diameter?
Aaron Cox
Dec 9 2005, 04:47 PM
QUOTE (jd74914 @ Dec 9 2005, 03:37 PM) |
thanks
Last Q, whats the spring diameter? |
my blog has it all...but
they are your basic 2.5" ID x 8" springs.
ebay search 2.5" ID spring.....
jd74914
Dec 9 2005, 06:27 PM
thats what i figured, just didn't know if they were anything different than the norm.
Aaron Cox
Dec 9 2005, 06:28 PM
QUOTE (jd74914 @ Dec 9 2005, 05:27 PM) |
if they were anything different than the norm. |
they are yellow
Mueller
glad you could use them Aaron, they had just been collecting dust in my garage....
Aaron Cox
Dec 9 2005, 06:30 PM
QUOTE (Mueller @ Dec 9 2005, 05:28 PM) |
glad you could use them Aaron, they had just been collecting dust in my garage.... |
ooh...just the person i was about to PM.
on the spring hat (top), is there a pin used to retain it on the shaft???
TimT
Dec 9 2005, 06:48 PM
Not so mucha pin, but like a big paper clip looking thing. And you dont really need it
Also wire the springs to the hats.. through those other holes... keeps the springs in the proper place when you lower the car after having it in the air
Aaron Cox
Dec 9 2005, 09:13 PM
QUOTE (TimT @ Dec 9 2005, 05:48 PM) |
Also wire the springs to the hats.. through those other holes... keeps the springs in the proper place when you lower the car after having it in the air |
ziptie holes....
so the pin isnt needed? cool!
Mueller
Dec 10 2005, 01:27 AM
QUOTE (Aaron Cox @ Dec 9 2005, 08:13 PM) |
QUOTE (TimT @ Dec 9 2005, 05:48 PM) | Not so mucha pin, but like a big paper clip looking thing. And you dont really need it
ziptie holes....
so the pin isnt needed? cool! |
yea, I kept the "safety pins"
those are designed to make spring changes quicker....loosen the spring, remove pin, slide off the upper hat, remove spring, reinstall new spring, the hat and there you go...you could put a long bolt thru there if you find that the spring has no tension with the car raised and some odd chance the hat/spring tries to slip off the shock shaft.....but you shouldn't really have to worry
736conver
Dec 10 2005, 11:52 AM
QUOTE |
Brian frenz gave me the coleman collars..... |
Glad I could help.
Aaron Cox
Dec 10 2005, 03:21 PM
thanks again fella's.... they may go on the car...today
