Allan
Dec 10 2005, 05:15 PM
I finally got my adapters off and have started to put on a set of Pedrinnis. The rears went on fine but the fronts seem to be a really tight fit where the boss on the hub fits into the rim. Is it normally a press fit? I know that there is a certain part number for the later cars and according to Slits these are the correct ones.
Allan
Dec 10 2005, 06:49 PM
Nobody running Pedrinnis?
Dave_Darling
Dec 10 2005, 07:16 PM
Look at the part number on the back. If it ends in ".00", and you have a 73+ car, you will not be able to fit the Pedrinis on the front hubs. If the part number ends in ".01", or you have a 70-72 car, then you may just have some rust on the hub, perhaps...
--DD
Allan
Dec 10 2005, 07:21 PM
Thanks Dave. I got them on. It's a pretty tight fit, especially if you don't run them regularly. You were right on the rust issue. If you change over to them you need to clean things up a little bit. These were tight but fit well.
Thanks...
