bd1308
Dec 11 2005, 03:29 PM
rarely happens when engine is warm, when cold the car shudders a bit when you let off the clutch. Is it a CV or a clutch plate and/or pressure plate and/or flywheel?
b
Andyrew
Dec 11 2005, 03:31 PM
Is it a new clutch?
I know my clutch (stage 4 clutch package from KEP) shutters as well. but thats just because its a really grippy clutch...
bd1308
Dec 11 2005, 03:34 PM
no it was replaced like 20K miles ago.
I thought clutches lasted a long time.
b
grasshopper
Dec 11 2005, 03:36 PM
sounds like your clutch to me.... but then again... i'm 15
Andyrew
Dec 11 2005, 03:39 PM
I'd say take it apart, and look at it. (post some pics too)
10 seconds there and you'll know your answer..
Cant take more than a day to R&R... 2 hours if you know what your doin.
bd1308
Dec 11 2005, 03:47 PM
it's probably oil soaked.....
this sucks, there was plenty of material on there this summer....
and the other disc was covered with rust goo stuff.
its too cold to do it this week, i'm going home next week for winter break and i'll look at it then.
b
bd1308
Dec 11 2005, 03:51 PM
would CVs cause this when they fail? I thought i saw something about the shuddering when they fail....
they havent been repacked in like 20 years probably....
b
mightyohm
Dec 12 2005, 02:12 AM
Nope. One of my CV's was clunking but it never made anything like a shudder.
It's the clutch. Either it was installed incorrectly, is worn out, or got oil soaked. That is pretty much it.
bd1308
Dec 12 2005, 02:28 AM
excellent. well looks like it'll be like that for a while. i need like a what, clutch plate, throw-out bearing, pressure plate and resurfaced flywheel? $300 dollars or so?
b
Rouser
Dec 12 2005, 04:35 PM
QUOTE (bd1308 @ Dec 12 2005, 04:28 AM) |
i need like a what, clutch plate, throw-out bearing, pressure plate and resurfaced flywheel? $300 dollars or so? |
Give or take, from what PP says.
But you're going to need some other hardware: new flywheel bolts, crush washer, O-ring, & pilot bushing/bearing, TO guide clips & arm bushing, and a clutch alignment tool. I mean, unless you enjoy going back in there often by not covering all the usual bases.
bd1308
Dec 12 2005, 04:41 PM
thanks Rouser.....
b
