machina
Dec 12 2005, 05:53 PM
i have noticed bearings on alot of different european motors have FAG marked on the edge.
is that the name of a company or maybe a standards marking like ISO, etc?
some real info would be great, keep the queer jokes to a minimum so this thread does not get pulled
tat2dphreak
Dec 12 2005, 05:56 PM
name of company I believe... I have 2 rear bearings with FAG on the box
VegasRacer
Dec 12 2005, 05:58 PM
J P Stein
Dec 12 2005, 06:01 PM
FAG rear bearings are the ones to get....much better than SKF.
SLITS
Dec 12 2005, 06:09 PM
Just picked up two rear FAGs at a cheap price...................
I'm a happy camper
Rick_Eberle
Dec 12 2005, 06:38 PM
Aren't they the Miata bearings???
mrdezyne
Dec 12 2005, 06:57 PM
FAG Bearings is in Joplin MO. I just about ran off the road when I passed it one day, HUGE sign on the front of the building "FAG", I thought it must be a national headquarters or something...
scotty b
Dec 12 2005, 07:04 PM
QUOTE (SLITS @ Dec 12 2005, 04:09 PM) |
I'm a happy camper |
So you've been to San Fran recently huh??
bd1308
Dec 12 2005, 07:13 PM
QUOTE (scotty b @ Dec 12 2005, 07:04 PM) |
QUOTE (SLITS @ Dec 12 2005, 04:09 PM) | Just picked up two rear FAGs at a cheap price...................
So you've been to San Fran recently huh?? |
or Corona...
Cap'n Krusty
Dec 12 2005, 07:25 PM
Porsche uses bearings from FAG, SKF, Glyco, and KS. Possibly others (like NSK) for A/C clutches and things like that. IME, and there's more than 40 years of it, they're interchangeable and the quality's always there. FAG is headquartered in Germany, SKF in Sweden. The Cap'n
Allan
Dec 12 2005, 07:34 PM
And I thought the reason you were trying to get rid of me so fast this morning was because you were at work...
bernbomb914
Dec 12 2005, 09:22 PM
he bought them on ebay
Bernie
Marlow
Dec 12 2005, 09:51 PM
I just installed SKF front wheel bearings on my 74. Got'em from the Pelican.
Made in Mexico.
Speedster07
Dec 12 2005, 10:40 PM
F A G also makes other parts, I just recived for my 944 a clutch slave made by them.
J P Stein
Dec 12 2005, 11:20 PM
I got a set of SKF that were made in POS.
Unfortunately, you can't tell they are bad till you torque down the big nut......then there was side play in one.....assholes.
Cap'n Krusty
Dec 12 2005, 11:34 PM
QUOTE (J P Stein @ Dec 12 2005, 09:20 PM) |
I got a set of SKF that were made in POS. Unfortunately, you can't tell they are bad till you torque down the big nut......then there was side play in one.....assholes. |
Care to describe the exact situation? The Cap'n
Aaron Cox
Dec 12 2005, 11:35 PM
what did you torque the axle nut down to?
J P Stein
Dec 13 2005, 12:47 AM
Doods:
I got off the turnip truck....but not the last one.
After the big nut was torqued to 250lbs, there was .02 or so side play in the bearing....in other words, you could move the hub in & out about .02. Iz'at exact enuff? The other side was fine.
mightyohm
Dec 13 2005, 03:19 AM
I installed a set of SKF rear wheel bearings a few weeks ago, everything went great. I was very careful to install them correctly.
dimitri
Dec 13 2005, 02:22 PM
Friedrich Fischer invented the bearing grinding machine in Germany in 1883 and
the ball bearing industry started. Fag is still carrying his name. It means Fischer
AG, actien gesellschaft, which translates into stock company. Dimitri
Lou W
Dec 13 2005, 02:33 PM
He should have changed his name
