Poor-sche Lover
Dec 12 2005, 07:40 PM
remove the wiper linkage assembly? I read in the Heinous Manual, and it seems a little vague. Something about removing a screw from the instrument panel? I am apparently missing something. Thanks.
Cap'n Krusty
Dec 12 2005, 07:50 PM
Remove the fuel tank, remove the fresh air blower assembly, remove the wiper arms and the covers and nuts below them, disconnect the wires (label or otherwise identify the connections), and remove the 6mm bolt(s) holding the assembly to the body. Piece 'o cake. work the wiper assembly out of the car. BTW, they almost never fail unless the posts freeze in their tubes. Have fun. the Cap'n
Rocket
Dec 12 2005, 09:08 PM
be careful with the 6mm bolts holding i in. they are connected to a rubber spacer taht you need. and it breaks easily.
i suggest taking the one under the dashboard off firts, and then taking the rubber spacer off with the wiper assembly. the other way, taking it off the assembly, dosnt work to well in my experiace. but i have only done it 2 times.
-rocket
