KaptKaos
Dec 13 2005, 11:26 AM
So I was reading Collectible Classics, a British mag, and they had a really neat 2 page article on the Alfa Gulia (GTV). The article was a laundry list of service items and intervals for the Gulia. It was broken down by intervals sort of like this:
Stuff to do:
Daily
Weekly
Monthly
Quaterly
Annually
2 Years
3 Years
Alot of the items were Alfa and Gulia specific, but some were just good common sense.
Anyway, if anyone wants to volunteer items for a maintenance and I will put the list together and share it.
If this has been done before, please send me a copy. =)
Thanks,
Joe
rcarpen22
Dec 13 2005, 12:11 PM
Oh I have a good one for my car!
Daily: Add oil.
KaptKaos
Dec 13 2005, 03:04 PM
QUOTE (rcarpen22 @ Dec 13 2005, 10:11 AM) |
Daily: Add oil. |
Hmmm.....
Ok, maybe I should be more specific.
messix
Dec 13 2005, 03:12 PM
daily- drive it.
weekly- put gas in it and check oil.
monthly-wash it and check tires.
quaterly-change oil and check valve lash.
repete.
KaptKaos
Dec 13 2005, 03:14 PM
QUOTE (messix @ Dec 13 2005, 01:12 PM) |
daily- drive it.
quaterly-change oil and check valve lash. repete. |
Hmmm.... I think I need to scan the article and post it. Back in a few with that.....
nomore9one4
Dec 13 2005, 03:27 PM
Daily...Rock it to make sure it is safely on jack stands
msglaigaie
Dec 14 2005, 04:59 PM
I used to take care of a rocket launcher and a bunch of rockets for the Navy. They had a program similar to what you are discussing. There was a file of cards that my junior seaman would head for first thing in the morning. I would have a chart posting the work schedule for the day. They would grab the days cards and start with the "dailies" things that had to be done every day. The card listed what, where, and how. It had a list of tools, lubes and any special equipment needed. My troops completed the task, checked it off on the 'Work Schedule Chart" and then go for the weeklies followed by any monthly, quarterly, or annuals. I kept up the chart from the master book which was updated by the guys in the "puzzle palace" and life was sweet. Is this what you had in mind?? MSG L
spare time toys
Dec 14 2005, 05:19 PM
My list has one item blow the dust off it every so often
KaptKaos
Dec 14 2005, 08:59 PM
QUOTE (msglaigaie @ Dec 14 2005, 02:59 PM) |
I used to take care of a rocket launcher and a bunch of rockets for the Navy. They had a program similar to what you are discussing. There was a file of cards that my junior seaman would head for first thing in the morning. I would have a chart posting the work schedule for the day. They would grab the days cards and start with the "dailies" things that had to be done every day. The card listed what, where, and how. It had a list of tools, lubes and any special equipment needed. My troops completed the task, checked it off on the 'Work Schedule Chart" and then go for the weeklies followed by any monthly, quarterly, or annuals. I kept up the chart from the master book which was updated by the guys in the "puzzle palace" and life was sweet. Is this what you had in mind?? MSG L |
Exactly.
I had to leave the office the other day, didn't get to scan it. I will be able to do it tomorrow (I hope).
r_towle
Dec 14 2005, 09:16 PM
Daily,
Check tire pressure.
Check brakes...
Check oil level, add if needed.
Weekly
Check lug nuts
Monthly
Check CV joint bolts.
Check tranny fluid
check brake fluid
Jack up front end.
Check bearings
Check tie rods
Check ball joints.
Check rear wheel venting clearance
Bi annually
Rocker cover removal
Clean and inspect longitudinal
Clean drain plugs on bottom of longitudinal
Remove Carpets, Clean floor boards.Inspect for rust
Wash under all parts of body and under fenders etc.
Annually
Grease and clean floor jack and jack stands.
Rich
IronHillRestorations
Dec 15 2005, 08:51 AM
check jackstands?
msglaigaie
Dec 16 2005, 03:00 PM
You missed a Daily Card
Daily- Topical application of alcohol to gastroinestinal sytem of inspector while doing walkaround inspection of paint, and glass surfaces. Oil level status and any needed top off prior to retiring vehicle for the evening.
Hooyaaa, MSG L
Air_Cooled_Nut
Dec 17 2005, 12:18 AM
PMS (Preventative Maintenance System for you civilians ) Mine was sonar. Yeah, the system worked well because it led you by the hand...because many of the people were idiots or didn't give a hoot. Maybe that's changed now that they require a high school degree (like that means anything nowadays... ).
jfort
Dec 17 2005, 04:20 PM
boy, am I your expert on the Navy's PMS system. it was neat because each maintenance card included a list of the tools and materials necesssary, the safety precautions, the level of expertise required, then the actual procedure. related ("while you are in there") items were also listed. it was connected to a navy-wide data base so that they could see patterns of broken things, determine the volume of spares to be carried, etc. feedback forms kept everything updated. it would be an interesting and effective template for a 914 repair and maintence system. starting with the owners manual and following with the collective expertise of everyone here.
