i assume tap the pin out.....
ive read the coupler is very brittle and will shatter
QUOTE (MarkV @ Dec 14 2005, 04:19 PM) |
Use some sealer on the side shift console when you bolt it back on the transmission. Mine leaked and I had to take it back apart a few weeks later. The recommended sealer is the aviation non-hardening stuff. I used the green Kuril stuff and it worked perfect. |
QUOTE (rhodyguy @ Dec 14 2005, 06:19 PM) |
you didn't really use wd40 for a penetrant did you aaron? k |
