messix
Dec 15 2005, 12:23 AM
i get this code C00D1197: Cannot play the file
trying to play the burn out
KaptKaos
Dec 15 2005, 12:31 AM
Its a quicktime file. You need to download the apple quicktime plug in for your browser.
Go HereDownload Quicktime 7 and install it. That should do the trick.
You can pay me later
bd1308
Dec 15 2005, 12:33 AM
apple strikes again
messix
Dec 15 2005, 12:46 AM
down loaded, and it tried opening with windows media.
messix
Dec 15 2005, 12:48 AM
this is what comes up first
Windows Media Player cannot play the file. If the file is on another computer, verify that you are connected to the network. If you typed a path, verify that it is correct. If the problem persists, the server might not be available.
Scott Carlberg
Dec 15 2005, 01:16 AM
would it help him IF someone had Saved the Burnout (like me)
and then emailed it to him instead?
Is the plugin one of those things, where you not only have to
download it, but then go and Open/Install the thing?
messix
Dec 15 2005, 01:23 AM
it worked on the p/c but not the lap top.
messix
Dec 19 2005, 10:48 PM
still having this problem. tried reinstalling windows media 10 and still doesn't work. if it makes a difference i'm on a wifi at home.
r_towle
Dec 19 2005, 11:22 PM
its a quicktime file.
go into windows media and in the properties area you need to deselect that windows media is you default media player...
Even though it cannot play a .mov file...microsoft in their infinite wisdom wont give up control so easy...
you basically need to config windows media player to step down and promote quicktime for .mov files to work with both players on the same machine...
rich
Dr. Roger
Dec 19 2005, 11:32 PM
all ya got to do is open Windows Explorer/File Manager
Choose Tools/Folder Options
File Types tab
scroll down to the file type exension in question... .mov I assume.
Highlight the file type MOV
hit the change button
choose quicktime
OK
OK
OK
Congratulations, you've just chosen to change your mov file association from Media player to quicktime.
r_towle
Dec 19 2005, 11:35 PM
because windows media player cannot play .mov files....why oh why was that association ever established....
bd1308
Dec 19 2005, 11:38 PM
just in case the windows media codec was used to record a movie ending in .MOV....
b
messix
Dec 19 2005, 11:47 PM
no movf in files. and no change to select. i'm on xp
Dr. Roger
Dec 19 2005, 11:48 PM
right mouse click the start button and choose explore
then follow instructions above......
i've got XP too.
messix
Dec 19 2005, 11:54 PM
cant find tools/ folders in explore
messix
Dec 19 2005, 11:58 PM
don't know what happened but i just did select all to restore the wm player and no its works?
Dr. Roger
Dec 19 2005, 11:59 PM
if you right mouse click the start button a menu appears. choose explore.
once that window appears there will be words across the top of the window.
messix
Dec 20 2005, 12:02 AM
ahhh . and i spoke to soon. tried to play the dry line.... didnt work
messix
Dec 20 2005, 12:07 AM
ok im there but cant find a[ mov]
Dec 20 2005, 12:12 AM
QUOTE (messix @ Dec 19 2005, 11:07 PM) |
ok im there but cant find a[ mov] |
right there ...
messix
Dec 20 2005, 12:15 AM
mine doesnt look like that. mny to mp2
Dr. Roger
Dec 20 2005, 12:20 AM
that's fine.
hit the new button
then type in mov in the little extension window.
then choose the player
messix
Dec 20 2005, 12:24 AM
done. thanx guys. i'm not at all a puter guy. thanx again for holding my hand though this.
