McMark
Dec 15 2005, 01:37 PM
Here's the setup. Oil cooler mounted at the front of the car. A/C condenser mounted on the trunk floor. Fan mounted on top of the condenser. Air flows in through the oil cooler and out through the condenser. Do I need a puller or a pusher fan? My guess would be pusher, but I really don't know the difference. Help?
Thanks!
Demick
Dec 15 2005, 02:05 PM
You need a pusher, because the fan is pushing air through the thing it is mounted to.
goose2
Dec 15 2005, 02:16 PM
sounds like you need a pusher....pushers are more efficient than pullers too (better to blow than to suck?)
McMark
Dec 15 2005, 04:36 PM
Now I have to see if I can come up with a better design.
If not I'll do it and see what happens.
jonwatts
Dec 16 2005, 01:44 AM
It's not that the condensor gets hot, it's that you're trying to cool the vapor as much as possible to (hold on to your hamburger) condense it. So by putting pre-heated air through it you might really be compromising the effectiveness of the A/C system. That's why in "normal" cars the condensor is always in front of the radiator.
Goose, some fans are made as pushers, some as pullers, and some as both (with slightly less efficiency). Your friend's might have been one of the latter kind so that his particular fan was more efficient as a pusher.
