So I cut the engine mount bracket off to repair my hell hole and it's time to put it back on. I did some repair to the long behind where the mount goes and on the underside of the long where it spot welds in. I think I did a decent job of keeping those areas to thier original geometry.
I tacked the mount in and took some measurements to make sure it's in the right spot. . . I measured both the left and right to some places on the suspension and original frame. I also whipped out the level. The hell hole mount is correct in every axis of translation and rotation except it's a half inch higher off the ground than the left mount The top tip of the mount is also higher than the long than the drivers side is
But in order to adjust the height (and keep the flange against the long) I'd be screwing up some other measurement.
When removing the bracket I drilled the spot welds out and they basically line up with what is left on the long. It's a little off but not so much to get me .5 inches in height, maybe 1/8"
So the question is, what should I do? Is the mount on the right side supposed to be .5" higher? Should I suck it up and plan on the rubber in the engine and tranny mounts to absorb the flex? (that sounds super sketchy). Should I make a spacer to lower the engine mount with relation to the bracket?
I would just move the bracket down, except then the old flange won't match up to the long. I was thinking I'd move it down, and bend the flange up to the long and just corner weld it. As opposed to spot welding it flat against the long
