Allan
Dec 16 2005, 02:47 PM
I have a guy flying in tomorrow to swap some carbs and he has offered to adjust my valves and tune the car. What exactly will I need? Upper & lover valve cover gaskets, sump-plate gasket(s), drain plug gasket, oil filter?
Thanks...
Cap'n Krusty
Dec 16 2005, 02:55 PM
Valve cover gasket kit. It includes the sump stuff, nuts, and washers. "Turbo" valve covers are nice, too, unless it's a 914/6. If it is, then early SC lower covers are a nice addition. Mahle oil filter. A case of oil. The Cap'n
SLITS
Dec 16 2005, 03:32 PM
QUOTE (Cap'n Krusty @ Dec 16 2005, 01:55 PM) |
Valve cover gasket kit. It includes the sump stuff, nuts, and washers. "Turbo" valve covers are nice, too, unless it's a 914/6. If it is, then early SC lower covers are a nice addition. Mahle oil filter. A case of oil. The Cap'n |
"And a partridge in a pear tree".....................
Hi Allan
J P Stein
Dec 16 2005, 06:30 PM
& a 13mm box end wrench, flat blade screwdriver, & a .004 feeler gauge.
Allan
Dec 16 2005, 07:23 PM
QUOTE (J P Stein @ Dec 16 2005, 04:30 PM) |
& a 13mm box end wrench, flat blade screwdriver, & a .004 feeler gauge. |
What's the deal with the special "must have" curved feeler gauge that Pelican sells?
SLITS
Dec 16 2005, 07:24 PM
QUOTE (Headrage @ Dec 16 2005, 06:23 PM) |
QUOTE (J P Stein @ Dec 16 2005, 04:30 PM) | & a 13mm box end wrench, flat blade screwdriver, & a .004 feeler gauge. |
What's the deal with the special "must have" curved feeler gauge that Pelican sells? |
Makes it a shitpile easier to get the feeler where it needs to be.....or so I'm told
ejm
Dec 16 2005, 07:29 PM
a
large drain pan is nice to have
TimT
Dec 16 2005, 08:15 PM
QUOTE |
take the 0.004 blade out from your feeler gauge set and bend it, I bought some 004 feeler stock.. when the piece Im using gets to beat up, I cut and shape another piece of the shim stock
J P Stein
Dec 16 2005, 08:16 PM
