Dave Bell
Dec 17 2005, 12:39 AM
Broke down an engine to get ready to build something..
Thought you would enjoy pictures of a clean case.
- Dave
Dave Bell
asdf
Dave Bell
Dec 17 2005, 12:40 AM
asd
Dave Bell
asd
Dave Bell
Dec 17 2005, 01:07 AM
Nother one
Dave Bell
Dec 17 2005, 01:09 AM
and another
michelko
Dec 17 2005, 02:20 AM
Holy
What did you use to clean the case. Looks like a jewel!
URY914
Dec 17 2005, 06:59 AM
Plug the holes and use it for a Jello mold.
Leo Imperial
Dec 17 2005, 09:03 AM
Great shots and an awsome job
The wide-angle shots are the BOMB
lotus_65
Dec 17 2005, 10:25 AM
how importaint is it to clean up like that? i'll be rebuilding soon, thanks.
root
Dec 17 2005, 11:34 AM
I know how you did it! Acetone and a tootbrush, RIGHT?
bd1308
Dec 17 2005, 11:37 AM
lets see the other side....
b
Dave Bell
Dec 17 2005, 11:52 AM
Well I had a little help...
Your local machiine shop will have a power washer for things like this..... I took the case halves to them and they came back with only residual bits of crap left on them... mostly gasket and sealant left over on some harder to reach surfaces. Following two shots show what the other side looks like as I recieved it back from the machine shop. Then I clean off the residual junk with scotch brite, small screw driver, small wire wheel on die grinder + degreaser or Lacquer Thinner.
So I still have the residual clean up to do on the other half.
Cost for the wash... not sure exactly since I had them pull the gears off of the old crank at the same time. Total cost for wash and gear pull was $40. My friiend Bill Greenway tells me he has gotten the wash itself done for as little as $15 to $20.
Dave Bell
Dec 17 2005, 11:53 AM
asd
Dave Bell
asd
root
Dec 17 2005, 12:28 PM
Dave,
Great job!
Let us see the heads when there pretty too!
bd1308
Dec 17 2005, 12:54 PM
is that outlet you have that GFCI tester on working okay?
b
TJB/914
Dec 17 2005, 01:26 PM
Dave,
That is so beautiful. You could make that 1st picture into a wall poster??
Hopefully Seanery is listening. BTW, Hope your tooth problem is ok.
When I did my restoration a number of years ago there was a guy in Indianapolis, IN by the name of Roger Reynolds (Ottowerks) who had a cleaning process. All the 356 guys used him. I sent my engine, fan housing, trans & a few other parts to be cleaned. When they came back they looked like they just came out of the casting mold. Very reasonable & worth the price. I wonder if Mr. Reynolds is still in business?? (He also had a real 1972 914-6 in pcs.) Hey, Seanery do you know him from Indy???
Tpm
Here is a pic to show.
Dave Bell
Dec 17 2005, 06:20 PM
Heads I bead blasted myself... I have a Harbor Freight Blast cabinet... it really cleans things up.
Dave Bell
Dec 17 2005, 06:21 PM
asd
Dave Bell
Dec 17 2005, 06:22 PM
asd
Dave Bell
asd
