While measuring the air flow on my carbs the motor would want to die when we put the meter on the stack feeding the #1 cylinder. All the others were fine.
Any ideas???
QUOTE (Headrage @ Dec 18 2005, 12:10 PM) |
While measuring the air flow on my carbs the motor would want to die when we put the meter on the stack feeding the #1 cylinder. All the others were fine. Any ideas??? |
QUOTE (rogergrubb @ Dec 18 2005, 11:17 AM) |
[when you say air flow, do you mean vacuum? |
QUOTE (Headrage @ Dec 18 2005, 03:21 PM) |
All the air flow valves were open around 1/2 - 3/4 turn. |
QUOTE (SLITS @ Dec 18 2005, 12:40 PM) |
You know Allan, being your friend, I can't stand to see you suffer this way..... So, Just bring that unreliable, nasty 2.7 down to the shop and I'll swap in a sweet running '73.5 2.4 CIS motor...no leaks, starts and idles smooth, altitude compensation..... And I won't charge you anything for the swap.... Killer deal....................... |
