19144jt
Dec 19 2005, 03:18 PM
I have two parts cars with the stock front sway bars that go through the inner fender well on each side. My driver that I'm fixing up does not have a front sway bar. Can I put one from the parts car on my driver? What does it intail??
Thanks, John
bryanc
Dec 19 2005, 03:35 PM
There is an article over at pelican parts describing the procedure.
Basically, you have to remove the gas tank, drill two 1" holes in the body, then mount the brackets. You will either need to swap a-arms with your parts cars or get the bolt on solution from weltmeister for the mounting tabs. The bolt on works ok, but welding them is stronger.
double-a
Dec 19 2005, 03:38 PM
just did this a week ago! i put in an aftermarket 22mm bar, but installation process is basically the same no matter what bar you're putting in. pelican's guide is very helpful, and if you run into any trouble, there are many here who can help.
~a
dlo914
Dec 19 2005, 03:39 PM
QUOTE (bryanc @ Dec 19 2005, 01:35 PM) |
Basically, you have to remove the gas tank, drill two 1" holes in the body, then mount the brackets. You will either need to swap a-arms with your parts cars or get the bolt on solution from weltmeister for the mounting tabs. The bolt on works ok, but welding them is stronger. |
here's the link to the article http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm
dlo914
Dec 19 2005, 03:41 PM
and here's the article for the rear sway bar if you decide to install one:
http://www.pelicanparts.com/techarticles/9...4_rear_sway.htm
rjames
Dec 19 2005, 04:30 PM
Anybody ever heard of the brand 'Turn 6' swaybars? I found a set of NOS, both front and rear for $195. Wondering if it's worth it, or if I should look to spend a little more for an adjustable and just get the front one.
Trekkor
Dec 19 2005, 05:51 PM
This older thread may help you.
here:KT
orange914
Dec 19 2005, 08:51 PM
im thinking about a front bar addition also, but is this going to worsen handling without the rear bar(oversteer/balance issue)?
Mueller
Dec 19 2005, 09:00 PM
QUOTE (orange914 @ Dec 19 2005, 07:51 PM) |
im thinking about a front bar addition also, but is this going to worsen handling without the rear bar(oversteer/balance issue)? |
tons, and tons of 914 came from the factory with only a front bar....
a stock skinny front bar is better than no bar at all...period
do not run a rear bar without a front bar, that is dangerous on our cars...
front bar only = yes
front and rear bar = yes
rear bar only = no
Trekkor
Dec 19 2005, 09:09 PM
with mueller.
I run both bars.
It seems that most do not
KT
jd74914
Dec 19 2005, 09:13 PM
you have the bar to end all bars tho
Trekkor
Dec 19 2005, 09:18 PM
True...
