East coaster
Dec 25 2005, 05:25 AM
So, if xmas formalities don't break my rhythm, this will be welded on today. Here's the drivers side front flare after cutting, fitting and prepping for welding. The rears are done, so after this one there's just one more and a couple of little rust spots to deal with and the metal work is done.......yay!!
East coaster
Dec 25 2005, 05:26 AM
nuther....
East coaster
Dec 25 2005, 05:27 AM
nuther...
smontanaro
Dec 26 2005, 08:47 AM
Pardon my ignorance, but what are the doohickies with the wing nuts?
Skip
JoeSharp
Dec 26 2005, 09:12 AM
Body pannel clamps. (Hobor Fright)
:PERMAGRIN: Joe
Lou W
Dec 26 2005, 11:58 AM
Keep the pictures coming.
McMark
Dec 26 2005, 02:08 PM
Awesome! With a gap as nice as that, that should be a breeze to weld in. Nice job!
East coaster
Dec 26 2005, 09:45 PM
So I managed to get it welded up before having to go stuff myself silly on xmas food. Here's the just welded, pre-grind look..............
East coaster
Dec 26 2005, 09:47 PM
Close up of the elimination of the side marker holes. made a patch for the big hole and just welded in the small hole. Not the prettiest welds, but I did it in several very small sections (like 1/2" at a time) to minimize warpage.
East coaster
Dec 26 2005, 09:50 PM
Here's a make believe setup for the back wheel/tire. Other than paying around, I wanted to see if it's going to fit without altering the inner lip of the flare. It's pretty close and I think it may need a little
Aaron Cox
Dec 26 2005, 09:52 PM
ive never seen those wheels before.....
cool. 9's?
East coaster
Dec 26 2005, 09:56 PM
17 x 9 rears, 17 x 7 fronts. 2003 911 wheels, I believe? Don't see these too often, don't know why? I think they'll look schweet when it's all together.
maf914
Dec 27 2005, 08:09 AM
Nice work. How did you make the cut? The gap you have looks very uniform and consistant.
East coaster
Dec 27 2005, 08:52 AM
I fit the flare to the body (it takes some trimming here and there to get it fit properly) and clamped it at the bottom with vice grips and then held it tight aginast the body, then traced the edge of the flare with a marker. Then just pull off the flare and I used an air saw to cut the opening. I did the rear flares with a saw-zall
before I had an air saw and it works fine too.
The biggest problem I had was the gap was too close to fit the butt welding clamps into. I had to take a 4" grinder to the edge to open the gap a little. It seems a shame to open the gap, but the clamps are worth it. Once it's all clamped up, you just tack weld in between the clamps, moving around alot so as not to heat up any one area too much. Once it's all tacked up between the clamps you can remove the clamps and continue welding.
maf914
Dec 27 2005, 03:23 PM
East Coaster, Thanks for the explanation. I hope you can post some more photos as you finish the installation.
dinomium
Dec 27 2005, 04:16 PM
QUOTE (Joe Sharp @ Dec 26 2005, 08:12 AM) |
Body pannel clamps. (Hobor Fright) :PERMAGRIN: Joe |
I would personally go for the Eastwood Co versions... HF is shonky at best for close tolerance tools
Eastwood Co
Looking forward to the finished result pix!!
nomore9one4
Dec 27 2005, 04:50 PM
Awesome! Its going to be one sweet ride when its done. I wish I had used steel flares instead of my fiberglass.Great job.
East coaster
Dec 30 2005, 09:39 PM
Well here's post grinding and a little dolly work
Allan
Dec 30 2005, 09:43 PM
That is gonna be so nice when you are done.
Can't wait to see the finished product...
East coaster
Dec 30 2005, 09:46 PM
Also finished fitting and welding the bottom seams where they meet the factory rocker/valance mounting points. I took some close ups of this area to help others doing steel flares. I could not find any close ups of this area before doing mine and it takes a bit of fiddlin' around in this area cause the flares really don't fit this area well.
The flare bottom is flat (or perpendicular to the fedner) and the factory fender bottom has an angled (about a 45) bottom. You need to gradually hammer and dolly form the flare into the factory shape, so that it goes from flat to angle gracefully. I then butt welded and ground out the welds so it looks pretty much like it came this way.
East coaster
Dec 30 2005, 09:47 PM
The rear of the flare....
East coaster
Dec 30 2005, 09:48 PM
Profile showing the angle to flat morph........
East coaster
Dec 30 2005, 09:49 PM
And the rear........
East coaster
Dec 30 2005, 09:51 PM
Hope this helps the next guy doing AA steel flares. Now I have the passenger side to do and they're done!
Dead Air
Dec 30 2005, 10:01 PM
QUOTE (dinomium @ Dec 27 2005, 02:16 PM) |
QUOTE (Joe Sharp @ Dec 26 2005, 08:12 AM) | Body pannel clamps. (Hobor Fright) :PERMAGRIN: Joe |
I would personally go for the Eastwood Co versions... HF is shonky at best for close tolerance tools Eastwood Co
Looking forward to the finished result pix!! |
[QUOTE]
Thanks for the cool site.
Why not just bend a tab on the fender and weld to that?
East coaster
Dec 30 2005, 10:27 PM
Still leaves a place for crap to infiltrate and cause rust at the seam. Although I'm sure it could be sealed and probably last just fine, from what I've researched butt welding is best.
