QUOTE (SLITS @ Dec 26 2005, 01:42 PM) |
Oh, and if you don't drop the voltage to the coil...it will work...it will burn the center electrode and contacts in the cap, disintegrate the rotor and burn the electodes on the plugs real fast and overheat the coil....it will throw one hell of a spark to the plugs though.. It can also trigger the led and cause a misfire due to the intensity of the discharge in the cap.. Tired and true "Don't ask me how I know that".... |
QUOTE (Teknon @ Dec 26 2005, 03:15 PM) |
It is the Bosch Blue coil now, with the resistor (right). If I do nothing else that should work. The Street-Pro with the Ultra-Coil has a trigger off the Bosch coil then it fires the Jacobs coil that feeds the dizzy. I check and see if a resistor is needed for the Jacobs. |
