double-a
Dec 26 2005, 03:00 PM
help! i'm trying to install an oil pressure sender for my triple gauge, and apparently i don't have a large enough socket to pull out the sender unit. what size is that nut? it's a stock 1.8 liter engine.
thanks,
~a
Brad Roberts
Dec 26 2005, 04:25 PM
Damn good question.
I *think* it is 27mm.
Here is what I suggest: grab a pair of needle nose pliars and grab the sending unit on the sides with the pliers. Start twisting. They should not be installed with more than 10lb ft or so of torque on them. You should be able to get it out without the socket.
B
double-a
Dec 26 2005, 04:58 PM
yeah, it's big... like the size of the steering wheel nut. i don't have a socket deep enough, i'll try with the pliers.
~a
Porsche Rescue
Dec 26 2005, 06:54 PM
If it is exactly the size of the steering wheel nut, Brad got it right....27mm. If so, 1 1/16 inch will work too.
Brad Roberts
Dec 26 2005, 07:03 PM
How about this:
The two large nuts that hold the shock through bolt on the control arm are.... 27 also They are actually identical to the steering wheel nut.. probably has the same part number..LOL
B
Brad Roberts
Dec 26 2005, 07:05 PM
Bingo:
Steering wheel nut: 900 078 007 02
Shock nut: 900 078 007 02
B
double-a
Dec 27 2005, 12:07 AM
no good, the sender insert is too smooth, nothing i have that will fit down that hole worked. and as a bonus i sheared off the male spade connector. lovely
looks like i'm back to finding a socket. i have a 1 1/16, but it's too big for the engine tin hole.
~a
double-a
Dec 27 2005, 03:31 PM
we were wrong.
the nut is smaller than 27mm. not sure what the exact size is, because my metrics don't go that large, but i managed to get it out with a us 1 inch socket. actual nut size is smaller than that.
but i got it done, i now have a functioning oil pressure gauge (and a nice third brake light, but that's another "while i was in there" thing). 10-bar pressure gauge reads six. normal?
~a
Mark Henry
Dec 27 2005, 03:45 PM
24mm....just checked
Allan
Dec 27 2005, 04:11 PM
QUOTE (double-a @ Dec 27 2005, 01:31 PM) |
~a |
Wouldn't that convert to about 88 lbs?
I think Aarons motor runs right about there...
SLITS
Dec 27 2005, 04:14 PM
AFAIR.... 1 bar = 14.7 lbs = 1 atmosphere
double-a
Dec 27 2005, 06:40 PM
just got back from a drive. gauge reads about 5 at speed, 2 or 3 at idle.
it came home on a flatbed, all of a sudden it won't start, which is nice.
cranks, sounds like it'll go, but won't fire up. fuel pump? coil?
i guess class is in session again
always an adventure...
~a
Mark Henry
Dec 27 2005, 06:43 PM
Points maybe...time to start a new thread
Porsche Rescue
Dec 27 2005, 07:21 PM
Last time that happened to me it was a wire off at the coil. I would look there first since you were working near the coil I think.
double-a
Dec 27 2005, 08:17 PM
QUOTE (Porsche Rescue @ Dec 27 2005, 05:21 PM) |
Last time that happened to me it was a wire off at the coil. I would look there first since you were working near the coil I think. |
yes i was. all the wires look good, and they're in their proper locations. i had just run out to costco and back, and when i tried to restart, it would not fire up. so how does one check the coil? i know they're not too expensive, i guess after 30 years it's due for a new one
~a
lapuwali
Dec 27 2005, 09:22 PM
QUOTE (SLITS @ Dec 27 2005, 02:14 PM) |
AFAIR.... 1 bar = 14.7 lbs = 1 atmosphere |
Nitpickers R us: 1 bar = 14.5psi = 100kPa = metric standard "atmosphere". The US standard is 14.7psi = 101.32kPa = 1.01bar = 29.92inHg. The usual variance will be about 102kPa to 98kPa at sea level, depending on the weather.
See what you started?
double-a
Dec 27 2005, 09:34 PM
eh, that's a little over my head, i'm but a humble graphic designer. so... what's the normal range at speed and idle for a stock 1.8?
~a
double-a
Dec 27 2005, 09:38 PM
update on the non-starting problem. hint: when your double relay looks like it's been sitting inverted in the engine bay with 1/4 inch of water inside, your car don' wanna start.
luckily, i had a spare. and yea the car did start, and it was very good.
~a
