i've got the 4 bolt hubs with bosses for 5 bolt.
i will drill and weld the studs in place but still need the studs.
what is the stock specs for studs height/width/length, and where's the cheapest place to buy them?
much thanks,
roger
QUOTE (rogergrubb @ Dec 27 2005, 01:43 PM) |
dang, that's right. i've got these Gotti's and they are 10" and i'm sure the offset isn't exactly right. i was assuming i would use bolt on spacers which have there own studs in them. right? or do you just use really long studs to go thru the hubs/rotors,spacers/and wheels??? all in one stud? |
QUOTE (rogergrubb @ Dec 27 2005, 01:48 PM) |
thanks so much royce. looks like i'll take a chill pill until my rear flares come in and i do some measuring... cheers, roger |
QUOTE (bondo @ Dec 27 2005, 02:03 PM) | ||
You're welcome! I'm in the same boat.. flares not done, spacer not decided, therefore stud length unknown. I can't even machine the hubs because I guess not all studs are exactly the same size. I was told to have studs in hand before machining the hubs just to make sure they'll fit snug. Now I'm thinking of getting a mill, so maybe that will be my first milling project. |
QUOTE (rogergrubb @ Dec 27 2005, 02:09 PM) |
do you have a thread on your flare project??? i'm getting FG Sheridan flares. In the past i've only rolled steel fenders. i'm thinking on going the rivet route for simplicity. which route did you go? |
