Aaron, I had a flipped ZD in there and felt there was too short between 2nd and 3rd and too long between 3rd and 4th. Went to a "M" 3rd and a "S" 4th so its mo' better.
With the 205x15 tires the tranny feels like I am in the powerband alot more as I go thru the gears. You'll see
Jacco, I have been running the 2056 for 5 years. I toasted the rings overreving at a track event missing a shift. Jake provided a new set of pistons with better rings sealing along with a Jake FI cam/lifters. Heads were sent to HAM to be checked over and Len changed out the upgraded springs/retainer/keepers. I was trying to get 500rpms of power over the stock setup which dies at 4500rpms.
Hoe gaat het? (see I do know alittle Dutch although writing and pronouncing it is really hard!)
Engine mods
96x71 with Jake pistons and rings
Jake 9550 cam with new lite lifters
26mm oil pump
Heads have 42x38 SS valves with 911 swivel feet adjusters, HS single springs,HDretainers, HD retainers
9to1compression
Deleted retard on the dizzy
Vacuum advance hooked up
2.0L SS HE's with a Bursch muffler
I dyno'd this engine before (4yrs ago) at 95hp at the rear wheels so now I am thinking its 100hp at the rear wheels as its got even more kick! Plus I want to see the dyno sheet with the torque and hp curve to see if I really picked up alittle more hp at 5000-6000rpms.
I'll run it at the next PCA dyno day locally to see. I know I won't be able to keep up with Eddie914 on the straight with his 3.2L but atleast I won't get passed in the first 200 ft coming out of turn one.
