redshift
Dec 28 2005, 11:15 AM
Lube with lithium grease?
M
Cap'n Krusty
Dec 28 2005, 11:20 AM
QUOTE (redshift @ Dec 28 2005, 09:15 AM) |
M |
Attract dirt and grit? Naaaahhhhh .......... The Cap'n
redshift
Dec 28 2005, 12:12 PM
=o)
Better plan?
M
Aaron Cox
Dec 28 2005, 12:17 PM
most cables come teflon dry lubed
redshift
Dec 28 2005, 12:25 PM
Teflon.... OEM is lubed then.
It's slippery, but not very uhh... slippery.
M
Aaron Cox
Dec 28 2005, 12:38 PM
will you install it already???!!!!
Dec 28 2005, 01:53 PM
QUOTE (redshift @ Dec 28 2005, 10:25 AM) |
Teflon.... OEM is lubed then. |
no luby on the cables ...
Andy
SLITS
Dec 28 2005, 02:52 PM
ah hell Miles...fill the tube with goat grease...it will be the only part of your car that doesn't rust!
Katmanken
Dec 28 2005, 03:57 PM
Motorcycle shops sell cable lubes in a spray can fer lubing those pesky cables....
Ken
redshift
Dec 28 2005, 06:56 PM
The grease I usually use probably wouldn't work on such a thick cable.
M
Mark Henry
Dec 28 2005, 07:30 PM
I lube my cable with K-Y
redshift
Dec 29 2005, 06:57 AM
Yes, I also lube my tailpipe with that stuff.
Kentucky Jelly..
M
Mark Henry
Dec 29 2005, 07:19 AM
JeffBowlsby
Dec 29 2005, 07:40 AM
The portion of the cable from the firewall back is in a teflon sleeved housing...agreed, no lubing needed.
But what about the front part of the cable in the tunnel, where there is metal to metal contact? There is a constant sawing of the braided SS cable and the friction points in the centertunnel guide tube. I would think its a good idea to lube the cable where it rubs inside the center tunnel tubing to prevent premature cable wear, premature guide tubing wear, and a smoother clutch action.
hotdgr
Dec 29 2005, 08:05 AM
QUOTE (bowlsby @ Dec 29 2005, 05:40 AM) |
But what about the front part of the cable in the tunnel, where there is metal to metal contact? There is a constant sawing of the braided SS cable and the friction points in the centertunnel guide tube. I would think its a good idea to lube the cable where it rubs inside the center tunnel tubing to prevent premature cable wear, premature guide tubing wear, and a smoother clutch action. |
I have used graphite-powder lube in some applications. Very slippery and doesn't attract dirt.
redshift
Dec 29 2005, 08:59 AM
How about around the pulley?
Where can you buy that black, gritty goo? Seems to be a.. baked on coating???
M
redshift
Dec 29 2005, 05:21 PM
Damn! I don't recall it being this insanely hard! Took HOURS to get the damned pin back in on the pedal end, and lock it down..
1. Too much slack taken up on pedal end.. spacer doesn't fit on clevis end.
2. One of the nuts on the clutch end was stripped out (*inside one) so now, I have one nut, and no spacer.. until I get the BALLS to adjust a 1/4 inch out on the pedal end, and find a suitable nut for the clutch end..
Hey, it works.. and better! FARG!
M
SLITS
Dec 29 2005, 06:37 PM
Rule #1: NEVER play with your nutz until they strip!
redshift
Dec 29 2005, 06:55 PM
And lots of KY!
M
