dinomium
Dec 28 2005, 11:52 PM
So ugmo is only running on half the holes and I am scratching my head! I put my hand down by the exhaust and only the driver side is warm, passenger side is COLD! This is a 2 liter with good compression all around, no mufflers on just HEs and the dreaded weber progressive. Here is a list of the things I have already tried to stop sounding like a sick Harley:
New
Spark Plugs
Cap
Rotor
Wires It is getting good spark
Readjusted the valves all are moving freely
Rebuild kit for Carb, re set float to specs with niffty home made float gauge!
Swapped from dizzy with points to pertronix
flushed gas
new fuel pump
New fuel reg and filter
changes manifold gaskets
Changed orinentation (speeling;^) of Carb. all four intake runner are getting cold...
New carb base gasket
Threw wrench and tore down Halley Barry 007 poster
Drank lots of Snow Cap
Asked Shane
So yeah, I dunno what is going on here, any advice is helpful. Even "Dude, get a real carb or go back to FI" at this point will werk!
Thanks
dtd
BMITCHELL
Dec 29 2005, 12:01 AM
You have chased the fuel system and most of the ignition system with the exception of the coil. I solved my problem with a new blue coil. My old coil was intermittent. Would run fine for a while then took a dump and only fire like a two banger.
dinomium
Dec 29 2005, 01:21 AM
yup, swapped coils too! It is very strange!
Bleyseng
Dec 29 2005, 09:20 AM
plug wires are swapped for 3 and 4 cylinders? try checking the firing order again. Even DaveHunt couldnt get that right one time.
rhodyguy
dude, get some real carbs or go back to fi.
k
bd1308
Dec 29 2005, 10:03 AM
QUOTE (rhodyguy @ Dec 29 2005, 09:20 AM) |
k |
BTDT, im saving my progressive for my type1-powered lawnmower
b
dinomium
Dec 29 2005, 12:56 PM
checked and rechecked firing order... good thing it is written right next to the dizzy!
Kevin, my birthday is coming up... nudge nudge!
HA!
motorhead
Dec 29 2005, 02:46 PM
firing order and rotation? I seem to recall one of the salty dogs around here getting the firing order correct but backwards recently. Probably not the first or the last.
MecGen
Dec 29 2005, 05:09 PM
Hey Dude
Intake to head gasket ?
Theses are big problem spot on both sides.
Later
Gearhead1432
Dec 29 2005, 06:01 PM
Timming? Another idea would be power to the coil. I had a short once that caused a lot of hair loss.
If the carb base is getting cold to the touch then the fuel mixture will not atomize completely. I have seen this way too many times on VWs from a 1942 Kübelwagen to 1970's beetles. This is one reason why centermount carbs can realy suck.
Throw it away and get something better like 40IDFs or FI.
Rob
