and i'm replacing the front suspension w/a fresh 911. (thank you "Porboys" in Oakland)
seems kinda' lame as i just built my SBC from the ground up. i know engines pretty well, just never done any suspension work before. =-)
second thing on my list is to install the vented cross drilled rotors on the front. (thanks Mar7ck)
lastly, i need to locate someone who can drill hubs to 5 bolt on a 4 bolt hub that has the 5 bolt bosses cast already.
any suggestions or thoughts would be GREATLY appreciated!
if you can lend a hand i can supply all the pizza and drinks you can throw down.
much thanks,
roger
